Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through June 28, 2009
Old    Dusty V (redrider)      Join Date: Mar 2009       06-16-2009, 3:51 PM Reply
I have a 2004 Enzo, I believe my steering cable is going bad. I recall being able to spin my steering wheel with little or no effort "Index finger steering." Now it is all of a hand over hand job to turn(when stopped. What is the consensus should i be able to steer/spin the wheel with one finger?
Old    K.B.C.            06-16-2009, 3:54 PM Reply
yes, probably need to switch out the steering cable. its a pretty easy job, just takes a few hours
Old    Tanner Russell (tanner)      Join Date: Oct 2005       06-16-2009, 4:11 PM Reply
Yep, time to change it. As Scott said... it's pretty easy once u get into it. It just seems intimidating!
Me and my buddy did mine in 25 mins. due to a little luck.
Old    Joe Sellhausen (joesell)      Join Date: Apr 2001       06-16-2009, 6:31 PM Reply
Tie a rope around the old cable before you pull it out. Then tie the rope to the new cable. Have one guy feed the cable into the hole, and have one guy pull the rope. It's a piece of cake.
Old    George Aslinger (mobv)      Join Date: Jun 2002       06-16-2009, 6:47 PM Reply
I've changed a cable in a Supra and a Centurion. In both cases I tried the rope pull withouth success. The cable was secured under the floor with zip ties along with other electrical wires. Forcing it out would do considerable damage. In both of these boats it is easy to remove the center floor and then replace the cable without any ropes.
Old    Dusty V (redrider)      Join Date: Mar 2009       06-16-2009, 7:00 PM Reply
Thanks guys, I bought an extended warranty so it should be covered. I just needed to confirm so i can push the point with my dealer.
Old    Tanner Russell (tanner)      Join Date: Oct 2005       06-16-2009, 8:33 PM Reply
Eh, I have a feeling he'll say it's a maintenance issue, like changing your oil...so not covered. But maybe not....goodluck!
Old    Kevin R Baugh (krbaugh)      Join Date: Mar 2002       06-16-2009, 11:18 PM Reply
The extended warranty is for the engine tranny and V drive the rest of the boat is not included
