Ok, lets start from the beginning. When you edge into the wake, you need to make sure you have both hands on the handle (elbows in) all the way up the wake. As you leave the wake, the handle should still be as close and low as you can get it (while still keeping your elbow in). You are probably spinning to blind because you are throwing the flip too hard and letting your handle out. Try relaxing a little bit, pulling in with both hands before leaving and standing up tall. If that doesn't work, you might be turning your head. You should be looking at the toeside shore upon landing.
