Old    Hate N Pain (hatepain)      Join Date: Aug 2006       05-26-2009, 4:50 PM Reply
One of the wheels on my trailer seems to be losing the grease in the BB. I've regreased it three times this season with minimal towing. One long trip but the rest have been a couple miles to the launch. Any ideas?
Old    Brett Yates (polarbill)      Join Date: Jun 2003       05-26-2009, 4:54 PM Reply
Is the seal bad? If you haven't done it in a while it could be a good time to redo the bearings, races, seals?
Old    Clay (cla10beck)      Join Date: Dec 2007       05-26-2009, 8:56 PM Reply
The seal on that side blown out and not holding the grease. I bet if you look at the back of the hub, you will see grease sprayed all over, which if you have drum brakes, means that the side with the issue is not braking with all of the grease.
Check out this link if to answer any questions
http://www.etrailer.com/tv-remove_inspect_reinstall_trailer_bearings.aspx
