Old    Taft Leissner (tl7)      Join Date: Feb 2005       05-24-2009, 9:38 PM Reply
Sorry for the pic quality. Looking at buying this prop. It's brand new but has been dinged. Would this need to be reworked or balanced or would it be ok as is?
Old    wakemann (wakemann)      Join Date: Apr 2006       05-24-2009, 10:06 PM Reply
You would need to get it fixed. Can't put that on "as is".
Old    Abe (reconabe)      Join Date: Jun 2007       05-24-2009, 11:27 PM Reply
you could probably run it, BUT you will feel serious vibration, and then that could rattle your drive shaft loose...
wait..running it would be BAD
Old    Bill K (bill_airjunky)      Join Date: Apr 2002       05-25-2009, 9:17 AM Reply
Get it fixed. Or at least fix it yourself. Having "fixed" lots of AirChair & SkySki wings over the years, I wouldn't have any problem just tapping it back into shape myself with a rubber mallet & a block of wood.
Old    Art (rallyart)      Join Date: Nov 2006       05-25-2009, 9:39 AM Reply
New damaged is worth just as much as used damaged.
Old    Taft Leissner (tl7)      Join Date: Feb 2005       05-25-2009, 9:45 AM Reply
How much am I looking at for repair? I'm in the Houston area.
Old    Jamie (yooper)      Join Date: Jun 2002       05-25-2009, 9:49 AM Reply
If you are getting a good deal on the prop, I'd just bend that back in place myself. Like Bill K said, use a block of wood and mallet, or I've used a crescent wrench adjusted down to the thickness of the metal and bent it with that.
Even as is, I think you would just BARELY notice any vibration.... that just isn't a very big ding.
Like I said though... You better be getting a good deal on a damaged prop.
Old    Jeff Baker (innov8)      Join Date: May 2005       05-25-2009, 9:54 AM Reply
You can get it repaired for about 90 bucks at a prop shop.
