Old    JT (jthst)      Join Date: Dec 2008       05-24-2009, 8:42 PM Reply
I am trying to replace the blue drain plugs in my motor - Mercury 330 HP Scorpion, that the dealer removed last fall. I've found 5 of the 7 drain holes but I can't seem to find the last two. I've been hanging upside down in my engine bay long enough that my neighbours are starting to wonder. Any help would be appreciated, photos would be terrific (I do have the manual).
I have located the port and cylinder block and exhaust manifold plugs and one other one closer to the stern (not sure what it is called). I think the ones I can't find are (as labelled in the manual) the check valve, and the water circulating pump hose or the fuel cooler to thermostat housing hose.
Help! Thanks
Old    Scott (chilidog)      Join Date: Dec 2007       05-24-2009, 9:20 PM Reply
I think there are two on the raw water pump, one on the inlet side and one on the outlet side, but if you lay next to the motor on the pass side they are right behind the fuel filter(looks like an oil filter) I believe they are one on top of the other, not sure about the rest, maybe hook up a fake a lake to your water intake and see where water comes out of the motor, there's only one way in and 2 ways out thru each exh manifold so that should help narrow it down, don't forget the little o rings too.
Old    Kyle Booth (booth_k)      Join Date: Feb 2009       05-24-2009, 10:32 PM Reply
My 330 has 8 blue plugs in the vdrive u have three on drivers side 1 exhaust manifold 2 lower block 3 fuelcooler right behind oil filter it is the hardes one to get. Pasenger side 1 lower block 2 exhaust manifold 3+4 lower and upper raw water pump just past fuel filter 5 recirculating pump hose it is 6 to 8 inches up from the raw pump hope this helps sorry no pics
Old    JT (jthst)      Join Date: Dec 2008       05-25-2009, 12:00 PM Reply
Thanks guys I'll continue to look tonight after work. This at least gives me some direction.
Old    mendo247            05-25-2009, 5:02 PM Reply
Fire it up for a sec. Should be pretty clear lol
Old    Brandon Burek (yubasanger)      Join Date: Jul 2007       05-26-2009, 5:41 PM Reply
Kyle has the correct locations here are photos of the locations
Old    Matt (duramat)      Join Date: Feb 2008       05-26-2009, 7:06 PM Reply
I have this kid around the house wandering without a purpose most the time, I managed to bribe him to put them very bottom two in
If I could just get him to learn to replace the impeller........
Old    JT (jthst)      Join Date: Dec 2008       05-26-2009, 8:09 PM Reply
Found them all. Thanks for all the help.
Old    Jonathan B (espritv8)      Join Date: Dec 2009       03-23-2010, 6:01 PM Reply
How tight should they be installed?
