Old    Joe Sellhausen (joesell)      Join Date: Apr 2001       05-23-2009, 3:59 PM Reply
I'm pretty sure that the flood of water I get every time I go out is from the shaft packing. It's an 01', and I've never even looked at it.
Well I looked at it today, WTF?
How are you supposed to get at it? Its under the V drive.
Are there any tricks that anyone knows specific to a v drive?
Please help.
Thanks, Joe
Old    Luciano Grimblat (luchog)      Join Date: Jun 2002       05-23-2009, 4:30 PM Reply
there are to opposite running nuts, adjust them a little bit, it needs to make a few drops from time to time still.
Old    Art (rallyart)      Join Date: Nov 2006       05-23-2009, 4:50 PM Reply
They make cheap, though not necessarily inexpensive, for packing nuts. You want two. West Marine and others carry them.
I bought a double open end wrench and cut the middle out to give me two short packing nut wrenches. Somebody with your boat can confirm the wrench size.
Old    Aaron Ware (99_slaunch)      Join Date: Oct 2005       05-23-2009, 9:49 PM Reply
They should not be that tight. I was able to use a pair of channel locks on mine and it worked perfect.
Old    Brad Walker (humboldt9)      Join Date: Jun 2004       05-24-2009, 8:05 AM Reply
I just tightened the packing nut on my '02 Sanger V210. You definitely have to be a contortionist to get to it. I bought 2 adjustable slip nut wrenches at Home Depot for about $15 bucks a piece and they worked really well. You can find them in the plumbing section of almost any hardware store. FWIW it only took about 15 minutes to get the right drip setting on mine. Good luck, the joys of owning a V-drive!
Old    Bakes (bakes5)      Join Date: Aug 2006       05-24-2009, 4:04 PM Reply
I stood on my head and tightened by hand. No wrench was needed
