Old    WakeMikey (wakemikey)      Join Date: Mar 2008       05-20-2009, 3:43 PM Reply
My blowers are somewhat noisy, and one emits a high pitched whining noise. Double entendres aside, are there any solutions to improve these blowers? WD40 or some time or lubricant?
I have the traditional cylindrical blowers. I have also seen squirrel-cage type blowers. I heard someone say Rule blowers were very quiet. I am not finding a round style Rule. Any good deals to be had on new blowers?
Also need a couple round 3" vents if anyone has a good link... Thanks!
Old    Mikeski (mikeski)      Join Date: Aug 2003       05-20-2009, 7:45 PM Reply
Run them for a few minutes then turn them off... USCG requires boats to flow air while underway so you should not need them once you come off idle.
If you are using them to cool amplifiers you can get axial fans that run silent.
Old    Dustin (ncsumalibu)      Join Date: Mar 2009       05-21-2009, 6:43 AM Reply
WD-40 works for me!
Old    WakeMikey (wakemikey)      Join Date: Mar 2008       05-21-2009, 6:54 AM Reply
Sorry my 3rd sentence above should read "WD40 or some kind of lubricant."
Hoping to drop her in tonight! 87 Supra SunSport
Old    Nate (mammoth)      Join Date: Apr 2005       05-21-2009, 8:24 AM Reply
My blower was making the same type of noise, Liquid Wrench with Teflon cured the problem.
The blower is a sealed unit so it might be hit-miss getting it to the right spot to kill the noise. It's easiest if you pull the blower so you can guide the spray straw as close to the blower shaft as possible. It may not go away immediately but after a few rides the lube will work it's way to the right spot.
Old    Stewart (stewart)      Join Date: Feb 2006       05-21-2009, 10:33 AM Reply
My blower gargled with Listerene and then she worked great.
Old    Sam (wake1823)      Join Date: Dec 2005       05-26-2009, 7:40 AM Reply
Corrosion X HD. works great as a lubricant/protectant.
