Old    Scott T (thescott)      Join Date: Nov 2007       05-27-2009, 9:43 AM Reply
Looking for some feedback from other Supra owners who have the Roswell push button swivel board racks. The internal lock mechanism on ours is beginning to fail causing the racks to occasionally swing out on their own. I understand this is a common problem. I’ve contact Roswell (they’ve been great) and was told for people with this issue, they are switching out the push button swivels to their newer S.I. manual swivel.
These - http://www.roswellwakeair.com/content/view/41/71/
Has anyone switched out to these? If so, what are your impressions, do they work well, etc? Seems a better design IMO.
Old    Supra Man (kdsuprassv)      Join Date: Dec 2006       05-27-2009, 9:51 AM Reply
I traded mine for the S.I. Manual version. They work fine as long as you remember to put the pin in once you are done with the rack.
Old    pdxWAKE.com            05-27-2009, 11:03 AM Reply
Yep the Manual version work great. Get them and you will not have to worry about the problems anymore. I also give props to Roswell for standing behind the product.
Old    Cal (phenom_1819)      Join Date: Jan 2008       05-27-2009, 12:37 PM Reply
Roswell just swapped my push-buttons for the pin-system last week after I had the same issue. We got to try them out over the weekend -- everybody much preferred the pins. They are much more user-friendly, and feel sturdier. Ditto on Diggs' props, huge thank you to Roswell for standing behind us on this.
Old    Andrew (ajf4242)      Join Date: Aug 2008       05-27-2009, 12:41 PM Reply
Do you have to personally call rosswell to get these switched out or do you go through the dealer? Just so happens one of my push swivel racks just went out this past weekend a few times doing what you guys have mentioned.
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       05-27-2009, 1:05 PM Reply
Like everyone else, the pin style work great. I really liked the push button, but they do seem to haev a high failure rate. There was too much "play" in the actual locking mechanism.
Old    Scott T (thescott)      Join Date: Nov 2007       05-27-2009, 1:27 PM Reply
Awesome - thanks for the feedback everyone.
Old    Aaron Ware (99_slaunch)      Join Date: Oct 2005       05-27-2009, 4:14 PM Reply
I have the old three push pin set up and mine started getting stuck. I took them apart and cleaned all the parts. I put some anti-seize on all parts when putting them back together and no more problems. It was quick and easy. Worth a shot
Old    John Bauer (jonyb)      Join Date: Nov 2008       05-27-2009, 6:51 PM Reply
I called Roswell last week and they said the pin swivel racks are on backorder. They're gonna call me back when they get some, and swap out the ones I currently have. Mine have the black rubber pushbutton on bottom and are getting very hard to push in. They also have a lot of play and you have to put the pin it while under power. That's a big annoyance to me.... Hopefully they'll call soon.
Old    mikebu (mikebu)      Join Date: Aug 2008       05-27-2009, 7:27 PM Reply
I would caution people to check the tightness of the bolt that screws in from the bottom of the pin-system swivel racks. We found a 3-4 inch bolt inside our boat last week while cleaning up and it turned out to be from the swivel rack.
Old    John Bauer (jonyb)      Join Date: Nov 2008       05-27-2009, 8:22 PM Reply
Good looking out Mike. I checked mine this Spring and made sure they were still tight.
