Old    Jason loucks (loucksa)      Join Date: May 2009       05-10-2009, 7:27 PM Reply
Heres the deal 96 v drive boat 350 throtal body efi merc, the light for the v drive is on above 1200 rpm, replaced the sensor on the drive its self but it still comes on and when I give its some gas even with the light on as soon as I hit 2000 rpm the engine cuts out and will stall unless I pull back on the throtal. I the v drive tied into the ecm or what.
Old    TigeMike (chpthril)      Join Date: Oct 2007       05-11-2009, 4:15 AM Reply
Fluid level? Low fluid level results in low fluid pressure = light.
Old    Jason loucks (loucksa)      Join Date: May 2009       05-11-2009, 5:07 AM Reply
All fluids are good
Old    Joe Sellhausen (joesell)      Join Date: Apr 2001       05-11-2009, 7:56 AM Reply
The fluid level might be good, but the oil pressure might not. Take out the sensor, and install a guage. See how much pressure you have.
Old    plhorn (plhorn)      Join Date: Dec 2005       05-11-2009, 12:09 PM Reply
The V-drive oil pressure wouldn't make the engine stall unless its seized (which I doubt). I think the problem isn't the vdrive but the engine.
Old    Nick Tomsyck (sidekicknicholas)      Join Date: Mar 2007       05-11-2009, 12:14 PM Reply
OUr V-drive light goes off when the bass hits. Check all the fluids, if everything sounds, smells, looks good....your light is nuts, join the club.
Old    Jason loucks (loucksa)      Join Date: May 2009       05-11-2009, 1:41 PM Reply
The engine runs great in neutral but when I give it gas in gear it cuts out
Old    Trace (trace)      Join Date: Feb 2002       05-11-2009, 2:05 PM Reply
It sounds like you need to change your fuel filter, and you need a new pressure switch for the Vdrive light.
Old    Jason loucks (loucksa)      Join Date: May 2009       05-11-2009, 6:12 PM Reply
fresh oil change, fuel filter, trans fluid and v drive fluid and new pressure switch. Im stummped and so is the dealer
Old    Brandon (yubasanger)      Join Date: Jul 2007       05-11-2009, 11:30 PM Reply
Walter V-Drives have a screen in the bottom for the oil pickup check and make sure clean, check hoses for blockage, check wiring to light and ground for possible short. If all that is good than some how your Oil pump went bad, #42a in the diagram.
Old    plhorn (plhorn)      Join Date: Dec 2005       05-12-2009, 1:09 PM Reply
If you have a leaky oil hose on the v-drive that can cause the light problem and it wont be visible because it will be sucking air in instead of dripping fluid out.
I still say its the engine though. You can rev up the engine in neutral and it doesn't stall out?
Old    Jason loucks (loucksa)      Join Date: May 2009       05-12-2009, 5:11 PM Reply
Thats right I can rev it up to 5000 rpm and its runs great but when I put it in gear it tries to get on plane but the its like the engine cuts out. Its very odd thats why I am wondering if the v drive some how is connected to the ecm and its shuting down the engine because the low oil presure light is on, thats what it seems like anyway. Any other thoughts???
