Old     (rmack)      Join Date: Jul 2005       04-26-2009, 4:20 PM Reply
Does anyone know a good place to order ballast puppy impellers? the part number is 6303-0001.
I have three ballast puppies that need impellers, but the local shop around here moved an hour away and wants $25 per.
Old     (lav)      Join Date: Jun 2007       04-26-2009, 4:51 PM Reply
Not sure where yellow ones are from but I have had good luck with these
http://www.marineparts.com/mpf/mpf665.aspx
and $25 is about what it is going to cost no matter where you get them if not more
Old     (stevev210)      Join Date: Feb 2005       04-26-2009, 5:04 PM Reply
http://www.defender.com/product.jsp?path=-1|311|53460|809302&id=200127
product code will be 301965
(Message edited by stevev210 on April 26, 2009)
Old     (rmack)      Join Date: Jul 2005       04-26-2009, 5:14 PM Reply
do they still make the black impellers with the brass fitting.
I had the blue one and the black plastic fitting stripped.
Old     (stevev210)      Join Date: Feb 2005       04-26-2009, 7:37 PM Reply
The black ones always seemed to break apart at the blades and would end up plugging something up. Since Ive swithched to the yellow ones, only one has stripped at the keyway knotch. I havnt used the blue ones yet.
Old     (wakesk8er2)      Join Date: Mar 2002       04-26-2009, 7:40 PM Reply
http://www.fairfieldsupply.com/servlet/the-948/jabsco-6303-0001-impeller%2Cflexible%2C6303%2Cneoprene/Detail
$17.20
Old     (chaser)      Join Date: Sep 2006       04-27-2009, 9:36 AM Reply
I hear there are green impellers out there now that are suppose to be between the black and yellow in terms of flexibility.
Old     (justintime)      Join Date: Mar 2009       04-27-2009, 11:38 PM Reply
yellow is for reversible pumps
as in a fill and empty pump
black is for 1 way only
Old     (javony)      Join Date: Oct 2006       04-28-2009, 8:50 AM Reply
I had nothing but problems with the black impellers. I have the reversible pumps and the black would always get stuck, but since switching to the yellow ones I've had absolutely no problem. They are suppose to contain some sort of lubricant in them??
Old     (justintime)      Join Date: Mar 2009       04-28-2009, 10:31 AM Reply
Nitrile is the yellow one, it can be run back or forward
Black, can not be run back or forward, that is why they changed here pumps and impellers the past 5 years
(Message edited by JUST-IN-TIME on April 28, 2009)
Old     (bchesley)      Join Date: Apr 2001       04-28-2009, 11:18 AM Reply
There is a new green impeller out. The yellow had problems with the centers spinning out on them because they were a little too soft. My dealer is only stocking the green ones now.
Old     (justintime)      Join Date: Mar 2009       04-28-2009, 11:19 AM Reply
good to know
looks like i need to stock up
Old     (stevev210)      Join Date: Feb 2005       04-28-2009, 5:10 PM Reply
anyone know where to get the green ones, or is a dealer thing only?
Old     (rmack)      Join Date: Jul 2005       04-28-2009, 6:44 PM Reply
ya, where can you get the green impellers?
Old     (talltigeguy)      Join Date: Sep 2003       05-14-2009, 5:34 PM Reply
Bump.
Where can you get the green impellers?
