Old    Skyler (skyler_25)      Join Date: Jan 2009       04-22-2009, 12:10 AM Reply
i made a post on hear a while ago. but i have an 06 MB B52V. ive put weight it in. i guess you could call it the passenger side wake. it wont stay crisp. as i edge in to the wake it starts to white cap at the top. anyone ever had the same problem or know what it can be?
thanks
Old    pdxWAKE.com            04-22-2009, 7:14 AM Reply
Add more weight to the passenger side. If you see more wash on that side start adding weight or moving people around to balance the weight. Also, you might speed up a bit if you are going slower.
Old    Skyler (skyler_25)      Join Date: Jan 2009       04-26-2009, 11:55 AM Reply
yea we've tried taking weight off it an speeding up. even moving people around a lot. it looks good when i cut out. but when i edge back in just folds
Old    Scott (chilidog)      Join Date: Dec 2007       04-26-2009, 3:18 PM Reply
Is your battery, sub, gear etc. all on the driver's side?? Maybe move what you can over to the passenger side, and instead of more and more weight on the pass side try and lighten up the drivers maybe. Is it all water ballast? lead? fattys?
Also maybe try going faster than you are now by 2 mph?
Old    Skyler (skyler_25)      Join Date: Jan 2009       04-28-2009, 7:24 PM Reply
sub is on the drivers side. battery passenger side. pretty even. its stock 1600 ballast. and a 600 pound sack in the nose. but i went out with just 1 other person and it was fine. but the other side had lost its pop
