Old    Jeff Reese (jeffr)      Join Date: May 2002       05-27-2003, 7:35 AM Reply
Ok… I got my trailer brakes adjusted when my boat was de-winterized about a month ago. They bled the brakes… fluid level was good… even had to use the lockout pit to back up small hills to driveway, so they seemed to be working much better…had no clunk when starting or stopping… all seemed good. I have taken out the boat a number of times locally and the brakes were working fine…. Till this weekend.
Just got back from a long weekend road trip… I am sure the stop and go driving getting back over the pass did not help… I did not have to make any sudden hard stops and did not notice any fluid leaks, but now when I apply the truck brakes the trailer slams into the hitch. I mean SLAMS. Even if I slow down very slowly.
After parking in the drive way and disconnecting the trailer I was able to push the brake actuator all the way in by hand with very little effort…. I assume it’s a bad mastercylinder.
I will check for leaks tonight… not sure if there is a way to test the cylinder.
Any recommendations on aftermarket or replacement mastercylinders?? I wanted to get some more info on brand and prices before I checked with my shop about it. Note I have the stock MC tandem trailer that came with my 98 Maristar. It has a 4pin wire harness, drum brakes, and a lockout pin for backing up.
I am also thinking about going to a 5 pin wire harness so I can back up with out the brakes activating… again I assume that is a function of what mastercylinder I buy.
Thanks for any help.
Old    leggester            05-27-2003, 7:53 AM Reply
championtrailer.com
Old    pwork (siuski)      Join Date: Feb 2003       05-27-2003, 8:16 AM Reply
I replaced mine this year, the tiedown66 unit from championtrailer.com seemed to be the best value. It was VERY easy to bleed!
Old    Trace (trace)      Join Date: Feb 2002       05-27-2003, 9:10 AM Reply
that's http://www.championtrailers.com/,
but my old MC trailer used a welded-on UFP (www.ufpnet.com) coupler, and wouldn't be interchangeable. none of the master cylinders are very expensive or much trouble to replace. don't bother trying to rebuild it. the free backing solenoids are fairly universal AFAIK, and also very easy to install esp if you're already doing the master cylinder.
Old    leggester            05-27-2003, 9:10 AM Reply
Sorry, that's 'trailers', with an 'S'
Old    Peter_C (peter_c)      Join Date: Sep 2001       05-27-2003, 10:29 AM Reply
Of course the local auto parts store just might have what you need too. Phone calls can never hurt. I have about fifteen more phone calls to make this morning.
