Old    Jacob Ruppert (jacobs0222i)      Join Date: Sep 2008       04-02-2009, 4:18 PM Reply
Just wondering if anyone has them with the Phat Tower because they look like they wont fit. I know that the KMT6 tower speakers are almost 20in across and the top of my tower is only like 32ish.
[IMG]http://i530.photobucket.com/albums/dd343/jrruppert/080.jpg[/IMG]
Old    Jacob Ruppert (jacobs0222i)      Join Date: Sep 2008       04-02-2009, 8:38 PM Reply
[IMG]http://i530.photobucket.com/albums/dd343/jrruppert/079.jpg[/IMG]
Old    Jacob Ruppert (jacobs0222i)      Join Date: Sep 2008       04-03-2009, 6:00 PM Reply
Does anyone have this tower with any speakers mounted on it. It has this stupid plate that prevents you from mounting on the tube. I'm going to cut one off to mount speakers or should I just build a box with some 6x9" in it and mount it to the plates?
[IMG]http://i530.photobucket.com/albums/dd343/jrruppert/havasu2008012.jpg[/IMG]
Old    Nick Tomsyck (sidekicknicholas)      Join Date: Mar 2007       04-03-2009, 9:15 PM Reply
I would just get whatever speaker housing you want, pop off the stock brackets and just use a bolt through the housing up into your plate, throw on a nut and it should be golden
Old    Swatguy (xstarrider)      Join Date: Jun 2007       04-03-2009, 10:13 PM Reply
I agree with Nick. Just drill through the plate and mount the speakers directly.
Old    Jacob Ruppert (jacobs0222i)      Join Date: Sep 2008       04-04-2009, 12:17 AM Reply
sounds like a good idea but i was kind of set on the KMT6 because of the price.
Old    Swatguy (xstarrider)      Join Date: Jun 2007       04-04-2009, 9:40 AM Reply
You still can.
Just unscrew the c clamp and the top will pop off. Drill two holesin the plate that line up with the holes left and re insert the hex bolts with a washer to take up the space. When you remove the top half of that c clamp it will give you nice flat piece that will fit flush to the plate If it were me I would cut a small strip of bicycle tube to put between the plate and the speaker mount A) to prevent marring B) as a shock absorber to keep things tight.
Old    Nick Tomsyck (sidekicknicholas)      Join Date: Mar 2007       04-04-2009, 12:14 PM Reply
Yeah, like it has been said.... pop off the stock brackets, then add a bolt.... the hole is too big, get washers and some little rubber gaskets like swatguy said and keep it from making noise and marking stuff up.
