Old    wake_addict (radikal)      Join Date: Feb 2004       03-30-2009, 10:04 PM Reply
hey guys i got a malibu vlx 08, inside i got the company rockford fosgate subwoofer 10 inch with the amp. I have a Kicker ZR1000 amp at home that i want to use in the boat but i want to ask you which subwoofer you guys recommend yo use with my amp. I got a 1 square foot box and its at my driver's feet. i dont want to spend to much money as well.
thanks a lot
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       03-30-2009, 10:19 PM Reply
If it's the stock sub it should be a RF 12" sub not a 10". If you want to reuse the stock enclosure you're wasting your time. It's not going to sound to great with a high powered sub in it, it will flex.
For $250 you can pick up an Image Dynamics IDQ dual 4 ohm 12" sub over at woofersetc.com and they say that sub will take 1000 watts rms all day long. 1 cu ft is the small sealed enclosure they recommend for that sub as well.
Old    wake_addict (radikal)      Join Date: Feb 2004       03-30-2009, 10:21 PM Reply
and do you think if i just reinforced it with plexiglass inside it can do the job ?
Old    Scott (snafu077)      Join Date: Nov 2008       03-30-2009, 10:24 PM Reply
Slide out the enclosure add some screws and silicone the inside edges. You should be good with that.
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       03-30-2009, 10:28 PM Reply
It's not that it's not air tight, it probably is. The material itself will flex which is bad for sub box sound quality. Don't get me wrong it won't sound horrible. You could always try it and see how it would sound. It just won't sound as good as a properly built fiberglass or MDF constructed box. That is the first thing us BU owners ditch when we're re-doing our stereos.
Old    wake_addict (radikal)      Join Date: Feb 2004       03-30-2009, 10:32 PM Reply
ok i C, i will check what they put inside, if its the box that came from malibu or a box my dealer made himself, any other sub options to go with my amp, want to be sure it goes well with the power and ohms at mono or i dont know hahaha i am not a pro !
(Message edited by radikal on March 30, 2009)
Old    John Bauer (jonyb)      Join Date: Nov 2008       03-30-2009, 10:35 PM Reply
Wet Sounds XS-12 is also a pretty good woofer.
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       03-30-2009, 10:38 PM Reply
Whatever sub you get you'll need a dual 4 ohm sub to get the 1000 watts out of your amp. If you run it at 4 ohms it's only going to put out 500 watts. 500 watts for most subs will sound nice.
Old    wake_addict (radikal)      Join Date: Feb 2004       03-30-2009, 10:40 PM Reply
kicker solo baric L7 in 10 inch can be nice ?
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       03-30-2009, 10:49 PM Reply
Yup but how will you use the stock enclosure with the round hole cut in it?
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       03-30-2009, 10:51 PM Reply
You could always do their cvx supposedly very similar to the L7 subs.
Old    wake_addict (radikal)      Join Date: Feb 2004       03-30-2009, 11:00 PM Reply
yeah ill check them, maybe if i put the 12 inch kicker solobaric and if i have a 10 inch now my round hole will become a square one without a problem at all, but 10inch for 10 inch can be a problem...
Old    John Bauer (jonyb)      Join Date: Nov 2008       03-30-2009, 11:11 PM Reply
You can cut the round hole to be square. I did it in another box.
