Old    CJ Meert (02ssv)      Join Date: Aug 2007       03-30-2009, 12:35 PM Reply
I have a 2002 Launch SSV and the engine is bogging down when I am giving it gas to get up on plane. I have since replaced the fuel filter and no change. Has anyone else had this problem? Any advice would be great.
Thanks
CJ
Old    Tickle (showtime)      Join Date: Nov 2005       03-30-2009, 12:40 PM Reply
this may be silly, but when was the last time your impeller was changed?
Old    CJ Meert (02ssv)      Join Date: Aug 2007       03-30-2009, 12:46 PM Reply
At least a year ago. Would that cause this? Sorry if that's a dumb question but i'm not the smartest when it comes to engines.
Old    Jon Allen (jon_a)      Join Date: Feb 2003       03-30-2009, 12:48 PM Reply
How's your transmission and v-drive fluid level?
Old    Tickle (showtime)      Join Date: Nov 2005       03-30-2009, 12:51 PM Reply
i had this happen on mine once when the impeller went... sorta like a limp-home mode, would only allow partial throttle... of course your engine temp would rise as well...
Old    CJ Meert (02ssv)      Join Date: Aug 2007       03-30-2009, 12:51 PM Reply
I will check those today Jon. The V-Drive light has not come on, and I don't notice any funky smell.
Old    CJ Meert (02ssv)      Join Date: Aug 2007       03-30-2009, 12:52 PM Reply
Tickle- How hard is it to change the impeller myself?
Old    Kevin Hoye (wakebrdr38)      Join Date: Sep 2006       03-30-2009, 1:12 PM Reply
Isnt the first thing to check water in the gas. I know that has been a problem for me before especially if it has been sitting all winter. It usually means emptying the water/fuel separator and adding some additive to your gasoline.
Old    Paul (psudy)      Join Date: Dec 2003       03-30-2009, 1:44 PM Reply
I had water in the gas of an old boat of mine. It would start and idle fine, but when you gave it gas and raised the bow, the water in the fuel filter would spill out into the carb and kill it. So since you already changed the filter, check the gas.
Old    Boatworks (kyboatworks)      Join Date: Jan 2008       03-30-2009, 1:50 PM Reply
There's a screen filter in the bottom of the fuel pump. Sounds like it's got some junk in it.
Old    salty87 (salty87)      Join Date: Jul 2002       03-30-2009, 1:51 PM Reply
if the fuel filter you changed is a water separator, it should get the water or need to be replaced again.
is your fuel vent line clogged up?...wag
Old    CJ Meert (02ssv)      Join Date: Aug 2007       03-30-2009, 2:07 PM Reply
I'll check the screen filter as well tonight.
Old    David Griffith (davidggriffith)      Join Date: Sep 2008       03-30-2009, 5:48 PM Reply
how many hours are on your boat? it could be your spark plugs
Old    CJ Meert (02ssv)      Join Date: Aug 2007       03-31-2009, 4:58 AM Reply
Just under 300. Do you think the plugs are bad already? I will have one pulled and check it. Thanks for all of your help.
Old    Luke the Drifter (tl_hereford)      Join Date: Nov 2008       03-31-2009, 7:42 AM Reply
Same thing happend to my boat, it would get up to 3200 rpm then go back to 3000 with the gas to the floor. Ended up being a oil pressure sensor. If the impeller looks good and you still have issues don't kill you master power switch until you get it to someone that can read the computer on your motor. If you turn your power switch off it will clear all the codes and nothing will show up when they go to read it.
Old    BMG (wackbag)      Join Date: Feb 2009       03-31-2009, 8:21 AM Reply
check your power and ground wire connection. Could be that simple.
Old    CJ Meert (02ssv)      Join Date: Aug 2007       03-31-2009, 8:38 AM Reply
Luke, Is that something that you fixed your self or did you have to take it in. Either way how much $$$ am I looking at?
Thanks,
CJ
Old    Luke the Drifter (tl_hereford)      Join Date: Nov 2008       04-01-2009, 7:40 AM Reply
I paid $75/hr for mechanic, he told me what was wrong and what I needed. I went to a auto parts store bought the sensor for $60 and put it in myself. I have a 2000 Indmar 325 assault and it takes parts for a 97 chevy 4.7L. The key is to find a good mechanic who will shoot you straight.
Old    LimoTinted (ridininmd)      Join Date: Jun 2006       04-01-2009, 11:28 AM Reply
What is the engine temp when it's bogging?
Old    CJ Meert (02ssv)      Join Date: Aug 2007       04-01-2009, 12:21 PM Reply
Engine temp is normal. I ran it for the first time since changing the fuel filter with a new tank of gas today. I also topped off the v-drive level and tranny fluid, cleaned filter and it drove like new today. Thanks for all your tips
