Old    endo            05-20-2003, 7:55 PM Reply
Is there any way I can get my depthfinder transponder off of my hull? I Used slow cure epoxy to attach it, and now I want to move it. Thanks
Old    Troy (liveoz)      Join Date: May 2002       05-21-2003, 8:53 PM Reply
You can always remove epoxy with heat. If you can get it hot enough without damageing the hull or the transponder, it will come right off.
Old    Peter_C (peter_c)      Join Date: Sep 2001       05-21-2003, 10:37 PM Reply
I used a hammer to remove mine. It is fun anytime you get to hit something with a hammer. The transducer popped right out and the glue stayed. Then I took the new transducer and glued it in the exact same spot.
Old    salty87 (salty87)      Join Date: Jul 2002       05-22-2003, 10:49 AM Reply
if you didn't prep the hull really good when you put it in, you might be able to lift an edge and peel it back. get a screwdriver under it and twist the screwdriver to lift it up.
