Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through April 03, 2009
Old     (olo3000)      Join Date: Mar 2009       03-19-2009, 9:44 AM Reply
I am about to buy a new rope and I was hoping for some good advice from the board. Share any thoughts you have about the following deals I've come across to help me decide:
Bullet Lines Power Core for $65
SL Fire Wire for $60
Accurate Fuse for $65
Accurate A-Line for $70
Any other suggestions would be appreciated. Thanks!
Old     (thedoubleupkid)      Join Date: May 2008       03-19-2009, 9:50 AM Reply
http://store.ridecwb.com/index/1449.0.49333.48008.43062.0.0
SK - 75ft Coated Spectra Mainline
(Message edited by thedoubleupkid on March 19, 2009)
Old     (wswb4lfe)      Join Date: Jan 2009       03-19-2009, 10:08 AM Reply
if you have one of those coated lines that are the non knot ropes does that change the feel of the pull behind the boat?
Old     (mytahi)      Join Date: Dec 2008       03-19-2009, 10:15 AM Reply
NO THEY JUST MAKE THINGS LESS OF A HASSEL....THATS IT. MORE EXPENSIVE BUT BETTER. THEYRE ALSO A LITTLE MORE STIFF SO IMO MAKE THE ROPE STRETCH LESS.....
Old     (thedoubleupkid)      Join Date: May 2008       03-19-2009, 10:23 AM Reply
Non-knotted ropes? I'm not sure how much that really changes the pull. After a couple pulls the knots shouldn't continue to stretch, elongate, or creep. However, knots do create weak spots in your line. That is where ropes tend to break, but that only happens at max load. I believe SL stitchs some of their mains which allows them not to use knots. But you run into the same problem upon max load the stitching can fail and you still have a busted rope. Mind you it is very difficult to put a line at max load. This only happens on a super hard fall when the rider does not let go of the handle.
Old     (wswb4lfe)      Join Date: Jan 2009       03-19-2009, 10:57 AM Reply
No. i meant the ones that are like glossed over and
are said to prevent knots.
Old     (thedoubleupkid)      Join Date: May 2008       03-19-2009, 12:07 PM Reply
The pull should not change w/ coating, if it does it is very, very minimal. Like you said it is there to prevent knots and have a clean feel sliding thru your hands upon a fall, pick-up, and start.
