Old    michael bowles (michaelb)      Join Date: Feb 2009       03-12-2009, 7:59 PM Reply
at about 3:44 shaun murray does a tail press through a turn and holds it through the intire turn crazy right.heres the link may have to copy and paste http://www.youtube.com/watch?v=Fk5f_22oYrI .i want to know how to do this/how hard this is/and if i'm dreamin if i think i could do this.any tips are very eperishated.
Old    Sammy Ruloph Jr. (samreye)      Join Date: Apr 2009       04-10-2009, 3:36 PM Reply
Dude, first you need a roam/flex board and then cut out on a heel edge open up for a butter slide then just transfer your weight to the tail locking your front leg can help if not both leg eventually from their its balance and control. i hope i helped that is one of my favorite parts to and i try to do that slide every time i ride my roam. i think he does it so good, so long, and such good form is because he is doing it behind a PWC behind the tower handle control will come into play because the tower wants to pull you up but if you want it to look like murray's lower the rope to a lower spot
Old    Ryan Con40 (ryancon40)      Join Date: May 2009       05-01-2009, 1:47 PM Reply
definitely finless, and a board with high flex tip/tail, unfortunately the the roam is the only board with flex needed for the slide. You can try it with your current board but don't expect the same distance. If you can find a big stretch of glass, this may help you take it a little further. Its very fun to do, even if its 1/100 the distance that Murray can do it.
Old    David Miller (otown_dave)      Join Date: Dec 2007       05-26-2009, 3:10 PM Reply
http://www.wakeworld.com/MB/Discus/messages/65919/677838.html?1237481279
Old    Les D. (ldebbold)      Join Date: Jun 2006       06-04-2009, 11:38 AM Reply
David, that is a great link. I love WW.
