Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through April 03, 2009
Old    Ray M (wakeborder5)      Join Date: Jun 2002       03-07-2009, 6:06 AM Reply
What kind of epoxy should I get for use on my board? Sorry for not searching, I'm on my phone.
Old    Brad Webb (04outback)      Join Date: Jul 2007       03-07-2009, 7:53 AM Reply
maybe this will help>:
http://www.wakeworld.com/MB/Discus/messages/559019/598669.html?1216339572
http://www.wakeworld.com/MB/Discus/messages/87668/621546.html?1220369153
Old    Jay T. (wakebrdjay)      Join Date: Apr 2008       03-07-2009, 8:39 AM Reply
If you have a larger dent that needs filled look into getting some micro-balloons to mix in with the epoxy.This helps two ways,1st it makes the epoxy thicker,so it stays in place better,2nd it is easier to sand.You can find micro-balloons at hobby shops in small amounts,Sig Mfg. makes it for model airplane construction.
Old    Michael Mueller (sacmule)      Join Date: May 2007       03-09-2009, 10:27 AM Reply
I use a 30 minute epoxy, it is far easier to work with since 5 minutes is just not enough time to mix the epoxy, work it into the crack, and then clamp it. I really want to be able to get the epoxy into the crack and have found that the 5 minutes epoxies set too quickly. Look for a 30 minutes epoxy that says it works on fiberglass, I am not sure what brand I use, but I have seen it at hardware stores. I use aluminum foil to protect the clamp from the epoxy, I use quick clamps with the rubber jaws.
