Old     (john211)      Join Date: Aug 2008       03-04-2009, 8:17 AM Reply
I want to pull out one my rear, hard-plastic ballast tanks to get clearance for another project. There appears to be a sensor screwed into the top (‘empty tank’ sensor?). It has a stainless flange with about 5 screws twisted into the plastic top. Do I remove this sensor by undoing the 5 screws, or will I find a connector for the electric line that I undo instead?
Old     (vr6mole)      Join Date: Feb 2009       03-04-2009, 9:24 AM Reply
sounds like you are talking about the water level sensor for that tank.
Just take the 5 screws off and pull the sensor off the tank. You can also disconnect the wires if you see any type of connector in the line somewhere.
