Old    jose sol (jass)      Join Date: Mar 2009       03-02-2009, 7:06 PM Reply
cmon guys help me out.. i have moomba lsv 07 it came with the stock ballast system wich is the front walkway bag and the two bags in the back by the V drive .. i just bought a 275 lbs sac and one big sac 700lbs that has the shape like the bow.
i have move around the ballast trying to find a bigger wake but no results..
what do i need to do? in what part of the boat should i place this two fat sacs that i bought?
do i need more weight in the back or in the front??
im not sure but i think the stock ballast is 400 for the one in the front and 275 each in the rear
Old    Nick Tomsyck (sidekicknicholas)      Join Date: Mar 2007       03-02-2009, 7:13 PM Reply
and you only needed to post this once.
Old    Brad Webb (04outback)      Join Date: Jul 2007       03-03-2009, 10:11 AM Reply
Greetings.
I have an '06 LSV.. I have running the stock 400 in center locker about about 400 in each rear locker (I have 750 lb sacs but don't fill them completely). The LSV Hull likes a little extra weight in the bow..
What speed do you ride? How long rope?
I ride at 21ish and 70' and am very pleased with my wake with approx 1200 lbs ballast..
Your '07 should have 400 in center locker and 400's in each rear locker.. ('06's came with 275's in rear..'07 switched to 400)
fill the center sac full (make sure it does not have too much air in it.. sometimes this one can fill with air and not get much water in it!) and start riding at your normal tow speed.. monitor the wake as you fill the rear sacs. you should have a nice clean wake above 20 mph with just the center bag full.
Also, do you have a wakeplate? if so.. how do you set it?>
lots of variables here.
Old    Andrew Carnacchi (07launch22ssv)      Join Date: Feb 2007       03-03-2009, 10:18 AM Reply
the stock 3 bag ballast in a 2007 LSV is 400 center and 400 in each rear locker..
