Old    Phil Dubbert (hype29)      Join Date: Feb 2007       02-25-2009, 6:47 PM Reply
I need some tips on removing window tint. I had the window regulator go out in my expedition and it took a big gash out of the tint. So I have to take the tint off and have someone retint it
Old    Daniel (cowwboy)      Join Date: Jul 2008       02-25-2009, 7:06 PM Reply
If you can rent a steamer that would be the best.
Old    scooter (spherren)      Join Date: Aug 2005       02-25-2009, 8:07 PM Reply
just peel it off, then use a razor blade and glass cleaner to scrape the glue off. should take you ten min.
Old    Big E. (wakesetter101)      Join Date: Oct 2005       02-25-2009, 8:08 PM Reply
Get a razor blade and a can of Windex. Pull all the tint off once you get under it. Then spray the glue with windex and scrape it off. Easy to do.
Old    Toneus (toneus)      Join Date: Feb 2007       02-25-2009, 8:53 PM Reply
Spray white vinegar on the tint. Then place saran wrap on the vinegar to hold it on the tint. Let it sit for 15 minutes and peal.
I swear, it works, I've done it.
You will find this on Google too.
Old    Josh Gosa (warwagon)      Join Date: Jan 2009       02-26-2009, 3:40 AM Reply
or you could just pay an extra 10 dollars when you have the window tint re-done and they'll do it for you
Old    Aaron (aarond0083)      Join Date: Apr 2007       02-26-2009, 8:05 AM Reply
Razor blade and Gunk glass cleaner. I just removed mine off my truck a few weeks ago to have it done darker.
Old    David (detonate69)      Join Date: Apr 2001       02-26-2009, 9:34 AM Reply
Razor Blade and goof off cleaner. takes about 10 minutes.
