Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through April 03, 2009
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-25-2009, 3:37 PM Reply
Ok wakeboarders, ive really been wanting to build a rail or a box i don't have much expirience any suggestions? what should i use on top?
Old    Jason Callen (westsidarider)      Join Date: Feb 2003       02-25-2009, 4:13 PM Reply
first thing i can tell you is use screws, not nails when building. also you first have to figure out if your going to float the rail or will it be mounted in the ground. if mounting in the ground figure out how deep the dirt is first and then start making your plans. if your floating it the first step is to figure out what you will use to float it. you want to do this to be able to build the framework around the floats.
as far as surface there are many many types of material you can use. Trex, benderboard, pvc sheet, pvc pipes(old school and dont last long but still works), rfp? the list goes on. anything that is somewhat slick will work. ideally you want something that will be thick enough for you do be able to countersink your screws so they arent sticking up
Old    RileyBangerter (steezyshots)      Join Date: Feb 2008       02-25-2009, 4:17 PM Reply
Jason you are so nice!
Old    Jason Callen (westsidarider)      Join Date: Feb 2003       02-25-2009, 4:29 PM Reply
thanks....i try
Old    Jack (element8456)      Join Date: Feb 2008       02-25-2009, 9:07 PM Reply
I'm thinking about makeing a box and was wondering what would be the best for the top material(the slideing material)? Also what should the width be?
Thanks Jack
Old    Jack (element8456)      Join Date: Feb 2008       02-25-2009, 9:10 PM Reply
Thanks Jack
Old    Nick Schrein (wakeboardern1)      Join Date: Aug 2007       02-25-2009, 9:33 PM Reply
either trex or pvc sheeting.
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-25-2009, 9:52 PM Reply
where can you get pvc sheeting?
Old    Jason Callen (westsidarider)      Join Date: Feb 2003       02-25-2009, 9:57 PM Reply
http://www.google.com/search?client=safari&rls=en&q=pvc%20sheet&ie=UTF-8&oe=UTF-8
