Old    gotpwr            05-15-2003, 6:05 PM Reply
Last weekend I borrowed an '03 Excursion with the 6.0L diesel from work to tow my boat out to Greenville, IL. I was completely blown away at how well it towed my boat! I set the cruise on 80MPH and it never downshifted out of overdrive once to maintain speed up hills. My 5.4L Expedition would've been in and out of overdrive constantly and down to second up hills to maintain 80MPH. Here's a pic of the setup from last weekend.
'03 Excursion with '00 Air Nautique
I'm thinking about ordering an '04. If I do, I'll definitely check the "Pimpdaddy Appearance Package"(22's and a 3" drop) box so that it looks like this F-250 below.
F-250 with 3" Drop and 22's
Old    walt            05-15-2003, 6:10 PM Reply
Dan I have always herd that you should not tow in over drive. It will kill your tranny.
Old    BoRed (sdboardr99)      Join Date: Aug 2001       05-15-2003, 6:10 PM Reply
Even if it doesn't shift out of overdrive on the hills, you should always turn off overdrive when towing. It's not a matter of the engine being able to handle it, it's the transmission. The excess heat generated will kill the tranny pretty quickly. It might be okay when towing in a flat area but not up hills.
On the other hand, don't take it out of overdrive or downshift going down hill to order to keep your speed in check. With surge brakes they will overheat really quickly.
Old    chase            05-15-2003, 6:10 PM Reply
I love mine! You can honestly barely tell you are towing a boat at all. Mine has the V-10 but it is still great at towing! Plus, you can fit 8 boarders and their gear!
truck
Old    gotpwr            05-15-2003, 6:21 PM Reply
Towing in overdrive is not an issue as long as the trans is not constantly shifting in and out of overdrive. The shifting is what generates the heat. On my Expedition I would lockout overdrive because it would do just that, shift in and out.
Chase, nice setup. The room is what sold my wife. In the Expedition it was seating for eight OR room for gear, not both.
Old    joseph poslosky (jposlosky)      Join Date: May 2003       05-15-2003, 7:23 PM Reply
Guys, Ford is stopping producion after 2004 on the Excursion...........Why drop that much cash on something thats going out of production???
Old    gotpwr            05-15-2003, 7:35 PM Reply
Because if I don't buy it in the next year, I won't be able to buy it new. What else is there that has that much room and diesel power? Last time I checked, Chevy wasn't offering the Suburban with the Duramax. For me, a pickup box is useless, I need room for passengers and luggage.
Old    chase            05-15-2003, 8:04 PM Reply
What does going out of production have to do with it being an ideal vehicle for me? I happened to get an insane deal on mine so re-sell isn't a problem. So why does it matter?
Old    BoRed (sdboardr99)      Join Date: Aug 2001       05-15-2003, 10:20 PM Reply
As I understand it, when towing in OD the fluid flow is decreased due to lower RPMs, the powertrain is being "lugged" and this allows for heat buildup which is the enemy of any tranny. Constant "hunting" for the right gear also causes heat build up.
And of course you need to make sure you change the tranny fluid regularly too.
Old    steveaz            05-16-2003, 1:09 AM Reply
Um, what many of you say about towing in OD is right, but were not talking about grocery getters here. We're talking about diesel trucks that are made to tow 15K. These trucks have serious transmission coolers and most have tranny temp gauges. Mine's never been above 190 towing about 8K up a 6% grade at 75 in OD. The red zone isn't til 280 and normal is 160. As for not down shifting on down grades....you're right, the Torque Shift and Allison's will do it for you..damn cool. So everything Bill says is true, if you're driving a regular truck, but does not apply to the Powerstrokes/Torqueshift and Duramax/Allison. Cummins.....well, so far they haven't been to successful putting a good automatic behind that beast so all bets are off.
Personally, I think I'd give Ford a little time to work out some of the kinks with the new 6.0's. As long as he's gotten a good one (most likely has if it was manufactured in the last couple months), I hear they're a beast.
BTW, the Duramax is scheduled to come out in the Burbs but not till something like '05'....That'll be tempting
Old    pwork (siuski)      Join Date: Feb 2003       05-16-2003, 7:36 AM Reply
I have a '02 Blazer. It is not the ultimate towing vehicle, but it works for us. As with most new trucks it is equiped with a 'lockup' torque converter. I only pull our boat in OD when I know it won't 'unlock' the converter, such as on the flats. If it stays locked up it will not generate excess heat, because nothing is slipping. Now, granted that isn't that often because of the smaller motor especially on trips to area lakes. But when I'm on the Interstate above 65 and on the flats I have noticed a signigicant increase in gas milage (2k vs. 3k no brainer). Just my .02 on small trucks. Why won't Detroit put a small (~3.0 L) diesel on smaller SUV's or light trucks? Imagine the milage and ease of towing for us not looking for a huge vehicle.
Old    damnation            05-16-2003, 8:03 AM Reply
I think the Excursion will make a comeback. With that 6.0 L International making less noise, getting better fuel economy, and producing more horsepower than the previous 7.3's, it makes the Excursion more attractive. Also, Chevy did release the Suburban with a diesel engine. I've only personally seen one, but it was definitely diesel. I don't like the looks of the Suburban though, at least when compared to the Excursion.
pwork, Ford is going to start putting a diesel engine in the F150 line for 2004, at least that was the plan anyway. I guess the F150 would classify as a "light truck" .
Old    Joe (superairdawg)      Join Date: May 2003       05-16-2003, 8:07 AM Reply
As far as towing in OD is concerned I've also heard it's not a good thing -- BUT -- the Ford manual for my F150 (5.4l)with the electronic transmission says to leave it in OD while towing... go figure.
Unless it's shifting in and out all over the place, I go by the book.
Old    Paul (paublo)      Join Date: Jul 2002       05-16-2003, 8:22 AM Reply
The new 6.0 Ford and the Chev Duramax use the 5 speed Alison transmission, which is bulletproof. It won't matter if it is in OD or not. I'm not sure if you could even tell if you were pulling a boat.
Old    Greg Davis (vortech347)      Join Date: Aug 2000       05-16-2003, 9:29 AM Reply
Ford canned the smaller diesel project for two reasons. 1) Until the oil companies are required to switch to ultra low sulfer diesel fuel the smaller diesels cannot meet the new emissions requirements that are coming next year. 2) The 4.5L v6 Navistar engine was scrapped by Navistar because of problems with the fuel system and Ford's decision not to put the engine in their 1/2 ton line of vehicles.
3/4 ton and 1 ton trucks are not required to meet the same emissions requirements so they can get the big powerful diesels.
When the new ultra clean diesel fuel replaces the current fuel you will see a surge in diesel powered vehicles coming to market. The epa has mandated the switch in 2006 but it will probably get delayed because the oil companies will have to spend enormous sums to change their refineries.
BTW, Paul the Ford uses a Torqshift automatic that is built by Ford. It operates in a similar fashion to the Allison in the Chevrolet but they are as different as the Powerstroke is to the Duramax.
I hope the manufacturers offer a smaller diesel powered engine for the 1/2 ton line of trucks in the future. My wife's Jetta TDI gets 45+ mpg and I would welcome getting 1/2 that in a truck.
Old    sandman            05-16-2003, 9:50 AM Reply
Quote: Towing in overdrive is not an issue as long as the trans is not constantly shifting in and out of overdrive. The shifting is what generates the heat.
Not necessarily true. Just because your tranny is not shifting back in forth does not mean it is not generating heat. When towing in OD your torque converter is much less likely to lock up. Cruising down the highway with an unlocked converter will create a lot more heat than towing out of OD with the converter locked up.
Old    abk22            05-16-2003, 11:01 AM Reply
For the right price you can get a Burb with a Duramax, yo just gotta know the right people, The Chevy People, I know the sons of the Local chevy dealer one has a Cadillac Pickup (silverado body, everything Cadillac) it is cool as hell! And of course a duramax GMC Denali XL with fat 22's it pulls one of those huge cigarette boats like a 45footer!
Old    Thomas Deneka (tdeneka)      Join Date: Aug 2002       05-16-2003, 1:07 PM Reply
More diesels will be here in the next five years. Just watch.
Old    shane (auto)      Join Date: Aug 2002       05-16-2003, 8:36 PM Reply
I tow in OD, I do not have an issue, I watch my tranny temps, I have real gauges, not the idiot lights. No half tons here.
Old    Paul (paublo)      Join Date: Jul 2002       05-18-2003, 9:53 PM Reply
Greg
Are you sure about the tranny in the new Ford 6.0? My Chev service tech said that they were the same, only a slightly different model # to denote the difference between the Chev and Ford versions. And a fellow employee has a new 1T Ford dually with the 6.0 and says it has the Allison too. I'm no expert, only know what I'm told
Old    gotpwr            05-18-2003, 10:11 PM Reply
Paul, the Torqshift 5-speed trans is an all new trans designed and built by Ford. They are made at Ford's Sharonville, OH transmission plant.
Old    shane (auto)      Join Date: Aug 2002       05-19-2003, 5:07 AM Reply
hopefully the new tranny's on the PSD are better than the old ones, talk about a POS.
