I had this system setup in my boat, but it restricts water flow pretty bad. I am fairly ignorant when it comes to wiring, so one of my buddies did it for me. We had our on a cig lighter plug, and two 750 attwood aerators. I think the power came to the switch and one pump went to each side of the switch. You will need a valve at the end of the fill pump to prevent any backflow. I had the fill pump mounted on the platform with the pickup under the water, and the other pump stayed in the sac (fatseat). We also used another single pump to help fill on the other opening in the sac, and found that this single without restriction was much faster than the semi-auto double system. Actually last night I had him break this system back down and wire them all back up for single use, for speed. Post again if you have any other ???'s
