Old    jjeboarder            05-15-2003, 12:11 PM Reply
Does any body use some kind of tower prop or support?
I have a Wakesetter DD and when i fold my tower down to fit in the garage the speakers on the tower hit the motor box!
I need some good ideas to build a support out of wood and maybe carpet it.
send pics if possible.
Old    Alan (tigeal)      Join Date: Jul 2002       05-15-2003, 1:06 PM Reply
What I do is tie up the tower to a hook in the ceiling. With a prop you would not be able to use your cover and it is in the way when working on the boat.
Old    jjeboarder            05-15-2003, 4:22 PM Reply
Alan you are a very smart man!
5min job vs 2hr. job
I can't belive i didn't think of that.
Thanks Alan
Old    millertyme            05-15-2003, 5:25 PM Reply
I fold mine down till it almost hits on the boat and use tie straps back to the tower where it connects on both sides. The straps hold the tower off of your boat.
Old    matt moss (mossy44)      Join Date: Oct 2001       05-15-2003, 5:39 PM Reply
i built something out of a 2x4 and covered it with carpet to use while in storage and while trailering. i can take pictures and post them on tuesday. the one piece lays across the bow from one side to the other. then, i took a circle bit and drilled a circle the the center of a little piece, cut that in half to make a half circle (looks like a skateboard ramp) then mounted that piece to the original 2x4. the tower lays perfectly into the half circles. took me about 30 minutes to make.
Old    Peter_C (peter_c)      Join Date: Sep 2001       05-15-2003, 8:07 PM Reply
I built this wood contraption to hold my tower securely in place. Took about 15 minutes to build. I towed all the time with the tower folded.
Old    andy zarlengo (colorider)      Join Date: Jun 2001       05-15-2003, 9:32 PM Reply
I built 2 tower props for mine. One for each side. It holds the tower up and off the gelcoat so I can get it in the garage. It takes about 15 minutes, a saw and some wood screws. I even made mine out of scrap wood from an old futon. Talk about a cheap project.
Old    Bill Bierbower (monstertower)      Join Date: Mar 2003       05-15-2003, 10:57 PM Reply
WOW, great innoviative ideas !!! I dont care if we do bother the shoreline slugs with loud music, we're a damn smart bunch of adreneline junkies
Old    chris_hargis            05-16-2003, 8:33 AM Reply
Oh yeah, when ever you are thinking about doing something to your boat, you should post it here, because someone has probably already done it and can provide some great ideas you may not have thought about. I love this site!!!!
Old    jjeboarder            05-17-2003, 9:04 AM Reply
Thanks for the info.
I'am going to build two supports out of wood, because I have to take out the pivot bolt on the tower so it will clear the garage door.
Yes I need an extra 1.5" to clear the door, its very tight.
