Old    Cal (phenom_1819)      Join Date: Jan 2008       02-11-2009, 7:50 PM Reply
I have two Inland Surfers and don't have any experience with wakesurf board racks. I worry that running with the boards in the racks will damage the boards. Is this an issue? Are there any that are better than others? Thanks in advance.
Old    Andrew Taft (taft)      Join Date: Jul 2006       02-11-2009, 8:01 PM Reply
So long as the boards are secure, and there isn't crazy excess pressure from a cord or clamp, they'll be fine.
Old    Bryan Locke (gwnkids)      Join Date: Nov 2003       02-12-2009, 2:18 PM Reply
My blue fits in the Dbot 5 nicely and the Black fits in a regular wake rack
Old     (beaner)      Join Date: Jun 2006       02-13-2009, 11:07 AM Reply
Check these out. Overhead like a roof rack, look very solid and secure. There are pics in the last issue of Wakesurfing Magazine as well. www.endlesswavesurfracks.com
Old    Joe B (sailing216)      Join Date: Oct 2007       02-13-2009, 2:15 PM Reply
No prices beaner. How much?
Looks good
Old    Rob (wakesurf_ohio)      Join Date: Jun 2007       02-13-2009, 2:40 PM Reply
$389.00 base with additional costs for size upgrades/different colors
Old    Cal (phenom_1819)      Join Date: Jan 2008       02-13-2009, 3:08 PM Reply
I ended up picking up a couple of these from onlyinboards... look pretty darn nice. They hold 2 wakeboards and 1 surfer each.
http://www.onlyinboards.com/ski-boat-accessories/krypt-combo-signature.html
Hope they fit above my built-in racks... guess I'll find out.
Old    WakeMikey (wakemikey)      Join Date: Mar 2008       02-15-2009, 3:36 PM Reply
My Monster Tower wakeboard racks hold my Inland Surfer 4-skim and a Hyperlite Broadcast no problem. There are little plastic inserts that squeeze the board, I had to trim them down just a bit with a knife.
Also remember to look for a rack that has plastic collars to protect the tower. The DBot5 combo rack does not.
I had an Ariel brand mirror and it really sucked.
Old    Chris Neal (renobruin)      Join Date: May 2007       04-25-2009, 11:41 AM Reply
Checkout Niceracks. I believe they are the only one who makes a double surfrack.
Old    Duffy Mahoney (duffymahoney)      Join Date: Sep 2008       04-25-2009, 12:05 PM Reply
I just got a nicerack from Wakeoutlaws and it's freaking awesome. Fits two boards perfectly. I've had others and this one is a way better design.
Old    Nikko (nikko1)      Join Date: Sep 2008       04-27-2009, 11:22 AM Reply
Do the niceracks come with some type of padding in between the racks and the tower? If not, did you put something in between?
Old    Duffy Mahoney (duffymahoney)      Join Date: Sep 2008       04-27-2009, 11:38 AM Reply
The racks have padding on the top and bottom of both forks. The padding isn't glued in, it sits in a nice rail system. The glued ones come apart over time. It's a very nice rack.
Old    Patrick (jetskiprosx)      Join Date: Aug 2004       04-27-2009, 1:05 PM Reply
DIY wake makes a good surf rack. I fit my LF and Inland Red Tide in it without any issue. If you only want to use one board though, it's best to wedge a PDF in there to keep it from moving around.
This isn't an issue when your are towing someone, but if you are cruising around I wouldn't leave just one board in the rack.
Old    James Harold (jdjjamesz)      Join Date: Mar 2008       04-27-2009, 1:09 PM Reply
I have the endlesswave racks and they are the best,im so stoked on mine. Upload
Old    James Harold (jdjjamesz)      Join Date: Mar 2008       04-27-2009, 5:35 PM Reply
you can put them on single rack poles to,and they keep your boards secure.
Old    Jonathan Tollefson (jon_tollefson)      Join Date: Oct 2005       04-27-2009, 6:28 PM Reply
What do you mean when you say you can put them on single rack poles? I think it means that you only need one post to secure the rack to. Is this correct?
Old    Nikko (nikko1)      Join Date: Sep 2008       04-29-2009, 2:09 PM Reply
Has anyone had any experience with Skylon wakesurf racks? Heard anything good or bad?
Old    TQ (motogod77)      Join Date: Aug 2008       04-30-2009, 9:47 AM Reply
I love my surf racks from www.wakeair.com - the best quality I have seen by far. Mine are two years old and look brand new - too bad I cannot say the same for my Skylon wakeboard racks
Old    Nikko (nikko1)      Join Date: Sep 2008       04-30-2009, 11:22 AM Reply
So you have wakeair surf racks, and Skylon wakeboard racks, and you don't like your Skylon wakeboard racks?? Can you give me some more information as to why you don't like your Skylon racks?
Old    James Albertoni (slimjim44)      Join Date: Feb 2009       04-30-2009, 1:22 PM Reply
I have the skylon wakesurf rack. Works good for me. Plenty of room, holds the board tight with no bouncing around. Only downside is the way they mount to the tower. They can be mounted at almost any angle.
Old    TQ (motogod77)      Join Date: Aug 2008       04-30-2009, 3:34 PM Reply
The Skylon racks are totally pitted and look like they have been in salt water and I live 3 hours away from the coast and the boat has only been in fresh water. Also the straps on the "S" Rack are garbage - the ends fall off in one day and they are a pain in the a** to hook in.
Old    David (colombiansurfer)      Join Date: Sep 2008       04-30-2009, 5:14 PM Reply
TQ - I had the same problem with my racks pitting and I am no way near any salt water. I called Skylon and one of there reps tried to punk me by saying I wasn't cleaning them right, etc.. I called his boss and told him what was said and how I was treat, along with calling my boat manufacture and I got a new set of racks in the mail a few weeks later. Also, the guy that tried to punk me... No longer there. They are aware of the pitting problems. Call them if they are still under warranty.
Old    Nikko (nikko1)      Join Date: Sep 2008       05-01-2009, 9:30 AM Reply
Is it a good idea to put your board bag on while your board is in the surf rack. I read about the sun delaminating boards, etc....What about just protecting the board from getting beat up in general in regards to the bumps, etc...from the boat.
Old    Scott McMillan (scottymc261)      Join Date: Mar 2009       05-22-2009, 6:56 AM Reply
I looked for a year or 2 for racks and decided to make my own and incorparate it into the bimini, and then i thought why not make it 70mph towable! Load boards in 5 secs, easy to reach, made if for under $400. Upload
Old    dtw. (notsobueno)      Join Date: Dec 2004       05-22-2009, 7:29 AM Reply
That is a STOUT bimini. Loving the surf racks too. Nice work.
Old    Greg "The Hammer" (leaks)      Join Date: Oct 2005       05-22-2009, 10:07 AM Reply
Endlesswave Racks are the BEST I have ever owned. the detailing, and machine work are flawless. well worth the $399.00 price tag. And did I mention you can stack up to 3 surf style boards on one rack ?
Old    Lionel (lionel)      Join Date: Nov 2005       05-22-2009, 12:38 PM Reply
Nice work Scott. Made your own Z5 cargo rack. Wish I had the patience/skills to do that!
Old    Trevor Gleadhill (trevorg7)      Join Date: Mar 2008       05-22-2009, 8:39 PM Reply
I ordered a double surf rack from nicerack this week. Comes in Thursday, will let you know.
Oh, it's with the evolution tower mount.
T
Old    Michael Ward (onemoretime)      Join Date: May 2009       05-29-2009, 7:38 AM Reply
Endlesswave surfracks are by far the best racks to secure your fiberglass boards. Whether you have two cross bars or one, no problem. Multiple boards, no problem.
application/mswordUpload
~$dlesswave Autumn Pic.doc (0.2 k)
Old    N L (drnate)      Join Date: Jul 2006       05-29-2009, 1:06 PM Reply
I am seriously considering endless wave myself. (I currently have the double Nice Rack). The reason I am considering the switch is because I have one surf style board (shredd stixx) and one skim style board that is very thin but very wide (trick boardz). Will the Endless wave rack fit them both on one rack?
