Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-01-2009, 4:45 PM Reply
Does anyone know the weight difference between the lf sst and the bamboo nick taylor integrity??? Mitch i've heard you have ridden both? Any Comments?
What is the difference between how they both ride?
Old    Carson (eviltweak)      Join Date: Jun 2008       02-01-2009, 6:55 PM Reply
the tnt bamboo is close to 10 lbs i just weighed ti
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-01-2009, 7:18 PM Reply
Wow is it a heavier board to you?
Old    Carson (eviltweak)      Join Date: Jun 2008       02-01-2009, 8:17 PM Reply
kinda its on the heavy side of normal i believe if it helps any mitch says his board of choice is the tnt i believe
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-01-2009, 8:24 PM Reply
Is it good for kickflips and shuvits and bigspins? Im on an sst rite now. You think the intreg. is lighter?
Old    Carson (eviltweak)      Join Date: Jun 2008       02-01-2009, 8:31 PM Reply
i do not know i am acually a beginner skater (attempting shuvs)but the tnt spins so fast effortlsly and it flips and spins on axis
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-01-2009, 8:35 PM Reply
oh ok thats good is it worth the money? Where did u order it from?
Old    Carson (eviltweak)      Join Date: Jun 2008       02-01-2009, 8:40 PM Reply
integrity-wake.com go on to wakeskating.com and pm DD after you order ask him the questions about your order it will take a week or to at minimum to get your board probably more. to me its worth it because integrity is indestructible and the tnt is the perfect size along with the prekicks. where do you live do you know anyone who has one that you can try.
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-01-2009, 8:47 PM Reply
no one i know has it whats pm dd???
Old    Carson (eviltweak)      Join Date: Jun 2008       02-01-2009, 8:49 PM Reply
where do you live? and go on to wakeskating.com and send a private message to DD(thats his screen name)
Old    Mitch (wakemitch)      Join Date: Jun 2005       02-01-2009, 8:50 PM Reply
I went from the 42 sst, to the 40.5 sst , to the bamboo tnt. Its a bit lighter then the 40.5 sst. the weight is perfect for the size board it is. weight is not an issue at all about this board. it also spins much faster and smoother then the sst. the integrity decks are designed to spin. the centre-fusion core distributes the weight so it spins on axis for shuvs and kickflips. the bamboo core also makes the integrity decks the stiffest decks so they are super snappy. they react quicker and pop faster then other boards, especially the sst. bilevels react extremely slow because the tail has to flex and then it pops.
also you never have to worry about your board breaking unlike the sst where you are constantly worried of nose diving it on a fall ripping the bottom deck in two.
patch, you dont need to pm dd. just email them directly on integrity-wake.com for your questions.
(Message edited by wakemitch on February 01, 2009)
Old    Carson (eviltweak)      Join Date: Jun 2008       02-01-2009, 8:57 PM Reply
when i ordered mine the email on integrity-wake.com they didnt reply but DD did
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-01-2009, 8:58 PM Reply
Ok thanks
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-02-2009, 5:50 PM Reply
Carson how do you pm on wakeskating.com?
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-02-2009, 6:18 PM Reply
or anyone that knows how?
Old    Carson (eviltweak)      Join Date: Jun 2008       02-02-2009, 6:28 PM Reply
When your logged in on the top it will say send a private massage then you click compose new and go fromthere the words I used will be off a little bit but see if you can figure it out
Old    Scott (scott_a)      Join Date: Dec 2002       02-02-2009, 6:32 PM Reply
Log in to wakeskating.com forums and go to the forums and at the top of the page it will read "You have 0 new messages"
Click on that.
That's where you can send and read your PM's.
http://www.wakeskating.com/forum/profile.php?mode=viewprofile&u=9838
There's DD's profile. Click on the 'Send PM' button on the left side to send him a message...
Old    Carson (eviltweak)      Join Date: Jun 2008       02-02-2009, 7:21 PM Reply
thank you scott my directions were fuzzy
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-04-2009, 5:41 PM Reply
Ok one more thing is the blue TNT with the green country the 09 graphic?
Old    Carson (eviltweak)      Join Date: Jun 2008       02-04-2009, 6:51 PM Reply
It's the same as the 08 they didn't change and itsvan islandboff Florida not a country
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-04-2009, 7:18 PM Reply
Yeah i had no idea what it was hahah thanks
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-06-2009, 4:01 PM Reply
I used to have a Byerly the 07 one is the Integrities top different from that?
Old    Mitch (wakemitch)      Join Date: Jun 2005       02-06-2009, 4:14 PM Reply
the integrity decks are much different. way more comfortable
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-06-2009, 5:17 PM Reply
Ok so they arent like the edges of the byerly where the soul of your shoe cant even touch the center of the board because the sides are elevated?
Old    Mitch (wakemitch)      Join Date: Jun 2005       02-06-2009, 5:41 PM Reply
no.
what do you want from a skate?
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-06-2009, 5:50 PM Reply
Stability mainly i always don't want to feel when i cut out or am cutting in to do a wake to wake trick i dont want to feel like im going to tip over
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-08-2009, 9:21 PM Reply
sooo yeah
Old    Mitch (wakemitch)      Join Date: Jun 2005       02-09-2009, 12:25 AM Reply
the concave and rails of the integrity decks make edging take a lot less effort. but the edges are still super forgiving so you can dance all over the lip with out getting tossed.
also, just riding more will help you out. when i first started wakeskating i would try to cut out on my toes to prepare for a heelside w2w and i would just tumble into the water. the main thing that will help will be to throw away your bindings and only wakeskate. you dont need trainging wheels.
oh snap!
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-09-2009, 3:04 PM Reply
Haha ok thanks one more thing do you know the phone number for integrity?
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       02-09-2009, 7:27 PM Reply
Never mind haha wow
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       03-14-2009, 4:25 PM Reply
How long did any of yours take to ship?
Old    Mitch (wakemitch)      Join Date: Jun 2005       03-14-2009, 5:07 PM Reply
back in the summer it took 2 months. but things are going much faster now. what board are you planning on getting because the 38 and 40 ltds are ready to ship.
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       03-14-2009, 5:20 PM Reply
i already ordered the 38 TNT about five weeks ago.
Old    Ollieshuvitz (ollieshuvitz)      Join Date: Apr 2006       03-14-2009, 6:50 PM Reply
yeah i ordered the 40 lemons about four weeks ago.
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       03-14-2009, 7:16 PM Reply
Was yours shipped?
Old    Ollieshuvitz (ollieshuvitz)      Join Date: Apr 2006       03-14-2009, 9:19 PM Reply
nope. still waiting. i was told 3 weeks, maybe 2 weeks, maybe sooner...im on 4 wks now, hoping to have it by the end of the month for some wakeskate trips; which would be 6 weeks.
i knew there was going to be a wait when i ordered it, BUT updates are always nice if there's going to be additional delays. i know a lot of people have waited months in the past, especially over the summer but i really want my skate haha. such a sick board.
did yours ship yet?
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       03-14-2009, 9:37 PM Reply
i think, ive emailed him and called but i usually dont get a reply untill monday. I have comps and trips coming uo and i really need it in. I'm so excited though. He said it would ship by the end of this week.
Old    Ollieshuvitz (ollieshuvitz)      Join Date: Apr 2006       03-14-2009, 9:41 PM Reply
yeah forsure, hopefully mine will ship around the same time as yours.
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       03-14-2009, 9:57 PM Reply
i'm hoping since its hand made there wont be any flaws
Old    Ollieshuvitz (ollieshuvitz)      Join Date: Apr 2006       03-14-2009, 10:32 PM Reply
nah, erich is really into perfection so i highly doubt there'll be any flaws.
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       03-14-2009, 11:00 PM Reply
Yeah its been so long I'm going out this weak coming up i hope il have it then
Old    Carson (eviltweak)      Join Date: Jun 2008       03-15-2009, 9:18 AM Reply
mine took 3 weeks to get to my door. i just got lucky when i ordered
Old    Abby (lakehippie)      Join Date: Jul 2008       03-16-2009, 6:26 AM Reply
I just ordered the LTD 38 but I got real lucky, my order was placed right after a product run so I should be seeing mine soon. The reason they take so long to ship is because they don't just mass produce them they really take their time and only do product runs when enough orders come in. These boards are WELL worth the wait time, they are going to last us FOREVER!!
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       03-16-2009, 9:10 AM Reply
Yeah mine should be coming today or tomorow
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       03-18-2009, 6:28 PM Reply
I FINALLY got mine in(rite when i got BACK from the lake)
Old    Ollieshuvitz (ollieshuvitz)      Join Date: Apr 2006       03-18-2009, 9:59 PM Reply
sick, at least you have it. ive been riding mitch's tnt while i wait, finally got use to it and now im not sure if i'll like the lemons more than the tnt haha
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       03-18-2009, 10:19 PM Reply
Hahaha how advanced of a rider are you?
Old    Ollieshuvitz (ollieshuvitz)      Join Date: Apr 2006       03-19-2009, 11:36 PM Reply
depends on what day of the week it is haha
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       03-20-2009, 8:51 AM Reply
big spins? kickflips?
Old    Ollieshuvitz (ollieshuvitz)      Join Date: Apr 2006       03-20-2009, 9:04 PM Reply
si senor. y tu?
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       03-20-2009, 10:39 PM Reply
nope im hopefully getting a bs bigspin next weekend
Old    Chris Anthony (russian)      Join Date: Feb 2008       03-29-2009, 6:52 PM Reply
Ollieshuvits rips......
on the tramp!
Old    Ollieshuvitz (ollieshuvitz)      Join Date: Apr 2006       03-30-2009, 4:19 AM Reply
dont lie to these kids russian, im only decent carpet skating!
Old    Adam Irmscher (nautiques210)      Join Date: Dec 2008       04-23-2009, 11:17 AM Reply
How is the bamboo tnt wake to wake?
Old    Mitch (wakemitch)      Join Date: Jun 2005       04-23-2009, 1:23 PM Reply
Adam, its amazing. i was nervous about it w2w because of the size made me think there would be a bigger chance for one foot to come off, but the concave and prekicks of the board keep the board really well. on other boards i felt like my feet would drift in the aiir while going wake to wake and my feet would shift around. but the with the tnt my feet stay secure the whole time right where i want them. also, even though the edges are really round the egdes grip well and the out line of the board allows the boad to cut really well into and up the wake.
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       04-23-2009, 3:52 PM Reply
It's amazing
Old    Adam Irmscher (nautiques210)      Join Date: Dec 2008       04-23-2009, 4:48 PM Reply
Mitch, thanks a lot i was curious on how it would track into the wake and being finless but now im really interested in getting myself one
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       04-23-2009, 5:35 PM Reply
It's really worth it i got myself one and its amazing. every trick is much easier now coming from a 42 sst
Old    Adam Irmscher (nautiques210)      Join Date: Dec 2008       04-23-2009, 6:48 PM Reply
Ya im on a catalyst right now and i want something that is going to be better all around
Old    chriscut            05-06-2009, 11:38 AM Reply
Integrity FTW
Old    Aaron (aarond0083)      Join Date: Apr 2007       05-17-2009, 7:54 AM Reply
I just picked up a Lemmons Bamboo (coming from a Vinyl) and I don't think I will ride anything else. I am a beginner on the skate but was landing huge heelside jumps consistently and coming close to 360 shuvs the first time I rode it.
I am riding finless so it is loose for sure but once you get used to it there is no going back. Forces you to really use your edge but still tracks very well.
