Old    TY-one-on (typhoon)      Join Date: Jul 2001       05-06-2003, 10:28 AM Reply
are components really that much louder or very close?
Old    aflefkov            05-16-2003, 12:00 AM Reply
I have the same question and am going to add a nice system once I get my tower and ballasts installed. Any advice would be nice.
Old    dliguori            05-16-2003, 9:30 AM Reply
I went with coax speakers- no crossover to wory about getting damaged.
Old    TY-one-on (typhoon)      Join Date: Jul 2001       05-16-2003, 9:34 AM Reply
I was looking at the pioneer rev series which look awesome. John strain has me looking hard at the crystals now though.
Old    whitechocolate            05-16-2003, 10:27 AM Reply
So You'r question would be. Is a 5-1/4 Seprate Louder than a 5 1/4 coaxials??? "Same brand same power"
Old    TY-one-on (typhoon)      Join Date: Jul 2001       05-16-2003, 10:29 AM Reply
exactly. but more so how much louder? noticably?
Old    whitechocolate            05-16-2003, 11:25 AM Reply
Well if you had a DB meter I don't know how much louder you would be able to see the One would be over the other. I would bet The Seprates would be able to handle/process the power cleaner (very imporant) with the external x-overs and the fact that they are using 2 speakers to do 2 things, The coax would work good for a Hull application where you don't want to drill a extra hole for the tweeter and Seprates would be better on a tower where the can fit in to cans or a box. Hoe that helps
Old    TY-one-on (typhoon)      Join Date: Jul 2001       05-16-2003, 11:30 AM Reply
I had a good idean but wanted opinions.
thanks
Old    jdr            05-16-2003, 11:39 AM Reply
Some of the higher end "coax" speakers do have external crossovers and do have 2 separate speakers. The tweeter is typically mounted on a bracket of some type that snaps over the mid range. So, based on Grant's definition above, would there there really be any difference in over all volume of one verses the other?
Old    TY-one-on (typhoon)      Join Date: Jul 2001       05-16-2003, 11:40 AM Reply
exactly what i was looking at in the crystals.
Old    whitechocolate            05-16-2003, 11:52 AM Reply
Jay is right: Its just not common to find Coxal's That are ususally high quality as seprates, If everything is the same like what jay is taking about I wouldn't think there would be a dif. It seems like when they make Seprates they Just seem a little more refined than a Coaxial's That what I based my opinion on. Example My Mb-quarts Seprates are much nicer looking/sounding than the Mb-quarts coaxial's other brands could be much diffrent
Old    TY-one-on (typhoon)      Join Date: Jul 2001       05-16-2003, 11:58 AM Reply
before i started looking at the crystals i was looking at the pioneer rev's. they look great but the speacs are about even between the co-ax and the component. that is what got me thinking.
www.pioneerelectronics.com/Pioneer/CDA/CarProducts/CarAlbum/0,1427,40~4010~40101700,00.html
Old    GD (greatdane)      Join Date: Feb 2001       05-16-2003, 12:08 PM Reply
Those pioneer speakers look nice, but how do they sound.
Good questions, howeever...
1) what is the advantage of separates on a tower?
2) what is the advantage of 6.5" vs 5.25" on a tower?
3) are two pair of 5.25" better than one pair of 6.5"?
Old    TY-one-on (typhoon)      Join Date: Jul 2001       05-16-2003, 12:13 PM Reply
those are pioneer's top of the line.
imo:
two 5.25's are better than one pair of 6.5's. more displacement
Old    whitechocolate            05-16-2003, 12:46 PM Reply
Dane:
1) what are the Advantages over What????
2) More speaker cone Area= More sound
3)No
The answers are General There is always a exception to the rule.I wish I could give better answers. Example Is 2-10 in woofers going to make more bass than "1"-12 in therory The 2 10's have more surface aera (more cone) so they should make more bass. But more often then not it dosen't work out that way, Unfortunaly Trial and error or Listining to some ones set up that is very close to what you have is the best way to make your desision, Theres so much Hype You have to let your ears make the final desision,
We were working on a guys car last night he installed Brand A speakers in his right door and brand b speakers in his left door and used the balance to listen to the diffreance. I was VERY suprised to hear what speakers sounded Much better/I could not believe how much louder a Just a diffrent set of speakers could sound. Trial and error my friend's
Old    jdr            05-17-2003, 7:24 AM Reply
I think Dane is asking what are the advantages/disadvantages of having coax's vs. components up on the tower. In my opinion, assuming all things are equal, I don't think there would be any difference. If you compare apples to apples as far as speaker quality. When riding on a wakeboard 75' behind the boat, I seriously doubt even the most particular audiofile would be able to tell the difference. Speakers inside the boat, different story.
Old    Timothy (timmy)      Join Date: Jul 2001       05-17-2003, 7:30 AM Reply
don't forget to factor in that car speakers are not designed for long throw, narrow beamwidth application.
Old    Matthew Melvin (melvinator)      Join Date: Apr 2001       05-19-2003, 7:48 AM Reply
Hey TY, I got the pioneer 4-way 6 1/2 speakers and they sound good. I can hear them behind my VLX and I am only pushing less than 75 watts each. Ebay for $68 shipped. You can't hear the bass behind the boat, but the mids and highs sound good.
Old    Cliff Griffin (seattle)      Join Date: Mar 2002       05-19-2003, 12:04 PM Reply
Ty,
I just ordered two pairs of the TS-D170R model. When I listened to them in the store, they sounded very clear at the top end of there capacity. I'm going to use them for a new tower box I'm installing. The power will be coming from a Pioneer 300w 4 channel amp.
I'll let you know how they work out.
Cliff
Old    TY-one-on (typhoon)      Join Date: Jul 2001       05-19-2003, 2:31 PM Reply
definately let me know. those are the one's i was looking hard at.
thanks
