Old    bmanİ            04-28-2003, 8:01 PM Reply
any tips on pulling this off?
Its a ts backroll with a fs 360 all with a grab, correct?
Old    Andrew (drewsmug)      Join Date: Jul 2003       07-27-2003, 6:27 PM Reply
i don't believe a grab is required to call it a pete rose
Old                07-27-2003, 8:02 PM Reply
I believe a Pete Rose is a grabbed toeside backroll with a blind 180...
Old    Shawn Jessup (bigjessup)      Join Date: May 2002       07-27-2003, 10:48 PM Reply
Pete Rose - ts back roll front side 360
Grab donest really matter, just makes it look alot better.
Old                07-28-2003, 5:17 AM Reply
You're right... I must have read the description on wakeboardingmag.com incorrectly. But, Higher Learning says that the grab is required...
Old    Andrew (drewsmug)      Join Date: Jul 2003       07-28-2003, 4:32 PM Reply
in detention parks says grabing the board helps or atleast reaching for the board as if you were to grab helps which may be where some confusion came from}}
Old    Matt VdA (mvda)      Join Date: Dec 2002       07-29-2003, 11:22 AM Reply
Get very comfortable your toeside roll to revert and your toe side 360's first. The do a toeside roll to revert and keep taking it through to a blind landing.
Old                09-05-2003, 11:48 PM Reply
In a pete rose a slob grab is required. It also sets you up for the handle pass better. The actual rotation is weird because after you grab the board and pass the handle your spin direction actualy changes. It's like you undo the revert part of the roll. If you come up short on the landing you go out the front. That is where the name comes from.
Old    Matt VdA (mvda)      Join Date: Dec 2002       09-06-2003, 9:20 AM Reply
Acually, it's a method grab. The rotation is not exactly smooth, but there is no change in spin direction.
Old                09-06-2003, 10:25 AM Reply
i want to try one also, is there any tips on it?
Old                09-07-2003, 10:43 AM Reply
pete rose's can be grabbed method, nose or slob. Usually nose.
Old                09-10-2003, 5:40 AM Reply
so does anyone have some tips?
Old    Christopher Stack (deepstructure)      Join Date: Jun 2002       09-12-2003, 4:21 PM Reply
wow brian. you can't land a ts front roll but you're going to try a pete rose? you got balls. can you do a ts backroll to revert like matt said? i would get really comfortable with that first...
Old    bmanİ            09-12-2003, 5:08 PM Reply
lol look at when i posted this.. april 28th.. it was wishful thinking i guess
Old    kyle (lfxstar)      Join Date: Jul 2001       10-01-2003, 1:42 PM Reply
ive been working on pete's for about a week, i got the grab (method,) got the rotation, got the handle pass, but im landing on my heels and slipping out on my bum bum, anyone got any pointers to not allow this to happen because i really really really want this trick. ive done the same thing probably 15 times....grab, handle, rotation, land on board, bum bum
Old    Christopher Stack (deepstructure)      Join Date: Jun 2002       10-01-2003, 2:08 PM Reply
as we always say kyle, video video video. though it's funny you're falling out the back, as a common problem on the pete is people under-rotate it and fall out the front (and thus the name as everyone says).
remember, this is a ts backroll to revert with a bs 180, and a common problem on the backside 180 is over-rotating it and sliding it out. sounds like maybe that's what you're describing here.
another thing that would cause you to over-rotate this in that manner would be throwing the flip too hard. make sure you get nice pop and go up for your backroll. if you're spining the flip fast you'll have a hard time keeping your feet under you on the landing, just like a regular ts backroll.
make sure your shoulders are staying over your feet as you're coming out, like this:
pete1
pete2
*shawn watson pics courtesy of bump films higher education dvd
(Message edited by deepstructure on October 01, 2003)
Old    Matt VdA (mvda)      Join Date: Dec 2002       10-06-2003, 12:51 PM Reply
Landing on your heels and slipping out is the most common problem I've seen and experienced with the Pete Rose, despite the origin of its name. Make sure you are landing bent at the waist and with your knees also bent. A lot of people push their hips forwards as they try to pass the handle which causes them to land on their heels. Don't focus so much on the pass, but more on just pushing the handle into the right position. You might want to just land wrapped, or with very late hadle passes, the first few times. If you feel you are over-rotating the spin, try to spot the prop wash (behind you) as you land. Good luck.
Old    kyle (lfxstar)      Join Date: Jul 2001       10-08-2003, 3:52 PM Reply
shawn watson is better than me, hahaha, yeah thanks for the tip, it is totally a mental thing, i mentally am just like, dont under-rotate and in doing so i definately huck it to hard and over rotate, fun trick though
