Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 15, 2008
Old    Cliff (ord27)      Join Date: Oct 2005       11-12-2008, 2:08 PM Reply
I have always had the dealer winterize, but this year am thinking about doing it myself
my only issue is the oil change
I have the hammerhead, and from what I've read, the oil change is a major PITA
some posts on the Malibu Crew say that leaving the old oil in all "winter" could be bad for the pan and block
my thought was to winterize but not change the oil
till I hit the 50 hour mark next season
the oil was changed about 25 hours ago
do any of yall think that there is a negative to leaving the old oil in?
.........either through the "winter" (I do the " " cause we don't have a winter like some of yall do)
.....or after start up in the spring?
Old    Craig Glass (my_malibu)      Join Date: Feb 2008       11-12-2008, 2:25 PM Reply
change the oil
if you leave the old oil in the particulate in the oil will settle in the motor not good
doing the oil change is the easy part
you have a drain line from the bottom of the oil pan clipped to the passenger side block
unclip it run it through the rear drain plug, undo cap nut, and let the oil drain
after running the motor up to temp of course which you have to do anyway to fog the motor
the impeller is the pain in the ass
total time to winterize 30-60 minutes depending on how easy the impeller comes out
have any other question about winterize you're boat drop me a line have the same boat
Old    Face Planter (mastercraft1995)      Join Date: Nov 2002       11-12-2008, 3:40 PM Reply
Change ALL of the oil that is in your boat.
