Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 15, 2008
Old    davidgree (davidgree1)      Join Date: Apr 2002       11-09-2008, 12:59 PM Reply
How do you get the drain plugs out? They both have knock sensors (unlike my 2004) which make it difficult to get a wrench around them. There is a small nut on top of the sensors doess thiss need to be removed?
Old    Chris Brown (cbrown)      Join Date: Jan 2004       11-09-2008, 4:43 PM Reply
Take the 1/2" nut off and let the knock sensor hang then a 1" wrench or socket to get the remainder of the plug out. I am going from memory on the size but the process will remain the same.
Old    davidgree (davidgree1)      Join Date: Apr 2002       11-09-2008, 5:28 PM Reply
Thanks. The knock sensor on the 2004 was all one piece, no nut on top to remove and more accessible.
Old    Chris Brown (cbrown)      Join Date: Jan 2004       11-09-2008, 10:49 PM Reply
Yea the old one you just removed the wire and used a 7/8" to take it out. Starting in 06 they went to the new style knock sensors on both sides of the block instead of one like 05 and before.
Old    Bill K (bill_airjunky)      Join Date: Apr 2002       11-09-2008, 10:56 PM Reply
Channel locks do the trick on my 05.
Old    Bret (wakeride26)      Join Date: Dec 2006       11-10-2008, 9:02 AM Reply
The knock sensors should be hand tight. That is all. When you put them back in, if you can not remove them with your bare hand they are 2 tight.....
Old    Cory McLean (kikitlo)      Join Date: Jul 2005       11-10-2008, 11:46 AM Reply
I just removed mine this weekend. I disconnected the cable, put a crescent wrench on the big nut, broke the seal and removed it with the wire connector still on. It was on hand tight plus a little.
Old    Bret (wakeride26)      Join Date: Dec 2006       11-10-2008, 12:59 PM Reply
I had to complain about the hand tight thing because it seems like every one we have had to pull out this year when we did not have a large cresent wrench or something, was in to tight.
