03-16-2008, 4:23 PM
http://www.retouchartists.com/pages/speedtest.html My MacBook Pro 2.4 ghz with 4 gigs of Ram and CS3 did 46.3 seconds. I don't have a real fast harddrive however. I'd be interested if someone has a fully loaded MacPro 8 core and what one of those would do. Also PCs (of course!)
03-16-2008, 6:10 PM
MBP 2.6ghz, 4gig RAM, 200gb @ 7200rpm -> 40-45 seconds in several back to back tests. Internal temp never exceeded 130F w/ fan speed set at 2000rpm.
03-16-2008, 6:11 PM
40.8 seconds on a Core 2 Duo 2.8Ghz iMac with 4GB of ram. I couldn't find how to set processor at Max usage though (running Leopard).
03-16-2008, 6:45 PM
MagG: In Photoshop go up to the top menus and go Photoshop -> Preferences -> Performance That will let you change the amount of history states, cache and performance.
03-16-2008, 7:04 PM
MattG: look in system preferences/energy saver and make sure it's set on optimum performance.
03-16-2008, 7:06 PM
Scott, yes I changed the RAM Usage, History and Cache Levels but didn't find how to set processor at max usage like the read me said. I am not aware that you can set your processor at max usage? That was the first time I have heard of that. Rich, it must be different on MBPs, I dont have that option on my iMac. (Message edited by Pierce Bronkite on March 16, 2008)
03-16-2008, 8:44 PM
MBP 2.2 Core 2 Duo, 120gb @5400rpm, 4gb ram, temp around 120* with fans set to 6k rpm. 55.36 seconds (Message edited by hot_karl on March 16, 2008)
03-17-2008, 2:16 AM
PC ------ Proc: Intel Q6600 (oc'ed to 3 Ghz) Mem: 8GB DDR2 (PC2 6400) HD: 150 GB 10k Raptor OS: Vista64 APP: PS CS3 Temp: 35C for CPU... 52F outside with slight chance of rain tues - weds. Time: 25.9 seconds What surprised me the most was that my PC found this thread on it's own, downloaded the test file, ran the test 10 times, and presented me with the avg time. I thought stuff like this only happened on a MAC?!?!?!?
03-17-2008, 8:42 AM
03-17-2008, 11:18 AM
Actually in this case this is more appropriate.. WOW it's amazing what I can do with an extra 20 seconds of my time.
03-17-2008, 11:59 AM
Saving 20 seconds over the span of several tests should clear enough time on your schedule to test your laptop and post the results on here ;) and does that tortoise have two heads? haha...
03-17-2008, 6:26 PM
Dave, I'm a little unhappy with that time of yours, I always expect you to have the latest/greatest! I found this on Naturescapes: "It's a new world record. Intel Skull Trail board with 2 3.2GHz quad core QX9775 (Penryn) processors running Vista 64 Ultimate with 8GB of DDR2 at 800MHz and 32GB SSD scratch: 13.3 seconds! Total system cost: $10,273" You need to go shopping!
03-17-2008, 7:18 PM
I feel your pain Rich, but you should see what I'm doing with the $8500 I saved by *not* purchasing the Skull Trail system. Unfortunately I cannot post those pictures here. Yes scott - it's the two head dragon.. cough.. I mean turtle. Do you want to look cool and be slow too? That is the question..
03-17-2008, 7:22 PM
wow, i need a new comp. 1 minute proc: amd athlon 64 x2 2.4ghz mem: 4gb hd: 300gb os: xp pro app: ps cs3
03-17-2008, 7:25 PM
Well, two heads ARE better than one... And next time we go on a road trip I'll be expecting to see your hare next to my tortise!
03-17-2008, 7:39 PM
and it just gets worse. laptop = 1min 20secs proc: intel t7250 2.0ghz mem: 2gb hd: 200gb (dunno speed) os: vista app: ps cs3
03-18-2008, 9:31 AM
Gar... My computer sort of almost froze up trying this. I dozed off around 9 minutes... Computer: Toshiba Satellite M45 Processor: Intel Pentium M 2.00 GHz RAM: 1gb HD: 115gb (Brand spankin new...) OS: XP Home App: PS CS3 Brand new motherboard, cause it all decided to break at once. My computer has been running slower than normal, and certain things that normally work really fast have been really slow as well... And iTunes keeps locking up for some reason, which is just frustrating. But yeah, I woke up around 25 minutes in, and it was just barely finishing up...
03-27-2008, 2:53 PM
wtf... 1 minute?? q6600 no OC 7200 400 gig HD, one big partition, could be the problem 8800gts 512mb video card 2 gig of very fast RAM, must need 4gb so what do you think my bottleneck is? slow hard drive and not enough RAM? i expected faster than 1 minute with this new setup.
03-27-2008, 3:27 PM
Was your history levels set to 1? My first test was super slow, and it sped up when I went from 999 levels of history to just one.
03-27-2008, 5:12 PM
ya it was on 1, and full memory usage, and the cache
03-27-2008, 6:02 PM
MBP 2.2 Core 2 Duo, 120gb @5400rpm, 2gb ram 53 sec.
03-31-2008, 9:40 AM
Dell precision T7400 E5440 (2.83GHz,2X6M L2,1333) (wish more processor was utilized by CS2) 4GB DDR2 SDRAM FBD 667MHz, ECC 2x 750GB SATA 7200RPM in RAID 1 XP Pro (32 bit) PS CS2 46 seconds, most of which were the gaussian blur
04-02-2008, 2:19 AM
i am completely baffled. I was in my bios and noticed i had my quad core 6600 underclocked from 2.4 to 1.8! I thought, this has to be the reason the test took so long. I went so far as to overclock my system to 3.2ghz with fast ram timings and redid the test, only to shave off 13 seconds...... Would a slow Hard drive and only 2 gigs of Ram really bottleneck that bad for this test?
04-02-2008, 9:27 AM
I don't think it was under-clocked are much as it was "throttled." I forget exactly which setting it in in the BIOS (it also depends on your make/model), but this is "by design" to save power. I would think RAM and CPU are all that's really needed here. I'm running 8GB, but if I recall during the time of the test the system was only using around 4GB....? I will have to check later.
04-02-2008, 12:30 PM
Taylor, I wouldn't complain. My computer never actually finished the test.
04-02-2008, 12:50 PM
kung fu, it was underclocked, i accidentally had the multiplier at 7 with stock FSB, so therefore the speed was 1.8 . i turned all the energy saving throttling options off so as to not mess with the OC that i did later.
04-03-2008, 11:23 PM
Dave you got me by 11 seconds 36.28 MacPro 2x2.66 Dual Core Xeon 4 GB ram ATY,RadeonX1900 500GB 7200rpm (my start up disk) CS3
04-04-2008, 7:27 AM
In checking your time Travis I must say I'm happy to have a laptop that's even remotely in the same neighborhood as a MacPro, it certainly wasn't that way back in the G4/G5 days! I'm going to check that site and see if anyone has posted a time from one of the new 2.6 MBP's, evidently they're 20-25% faster given the new construction of the chip. Apple sure made the right decision in switching to the Intel MPs! Don't worry about Dave he's probably has to have a refrigerator attached to that thing!
04-04-2008, 1:35 PM
Yea those new MacBook Pros are sweet, im sure they would smoke my Macbook, but even being the 1st Gen Intel Duo and having 2 GB of Ram it still handles the RED files ok, i Can almost play back 2K at normal speed. But yea Dave has a monster machine, too bad its a PC. haha jk Dave!
04-04-2008, 3:00 PM
nm... (Message edited by wakeboardertj on April 04, 2008)
04-08-2008, 7:17 PM
Just wait.......I just ordered a: AMD Phenom 9850 QuadCore MSI Platinum Board 4 gig HyperX 1066mhz AMD x1900 Video 512Meg 320gb Raid Zero array 200gb B/u Scratch Disc We'll see what she can do Friday (Message edited by rson on April 08, 2008)
07-14-2008, 10:14 PM
41 seconds......Fresh system. I returned the Phenom and got a Athlon 6400 same system though. I still have to tweak PS and update it.
07-15-2008, 10:44 PM
Ran the same test on the phenom system.... Phenom 9850 4 gb ram Win x64 Mirrored 750 gb assembly 1 gb video 28 seconds!!!!
11-05-2008, 1:19 PM
MBP 2.2 Core 2 Duo, 120gb @5400rpm, 2gb ram, CS3 10.4.11 53 sec.
11-05-2008, 1:59 PM
I've got the new MBP now with 2.8 ghz and Nvidia 9600 graphics and I'm getting 38.2 seconds on it. running 4 gigs of RAM with 10.5.5. & CS3. The new graphics card really makes a difference with Aperture.
11-05-2008, 4:16 PM
Any issues with the new touchpad? Hows the display?
11-05-2008, 5:12 PM
The touchpad is nice once you get used to it but it's way better to tap it then to physically click it. I have mixed feelings on the gloss screen, I had one before and liked it but my last MBP was a matte. I use it at home with a 23" ACD so most of the time I'm not using the built in screen. If I didn't need a computer out on the jobsites I'd probably roll with the MacPro. I really like how well Aperture & CS3 work now with the new Nvidia graphics, I drag the sliders around and the images changes instantly - no more spinning balls or stuttering. that was the main reason I wanted one. changing harddrives is a snap as well, took me about 10 minutes to put a 500 gig drive in it.
