Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through November 07, 2008
Old    Tom Adams (gunnertom4593)      Join Date: Sep 2008       11-04-2008, 4:12 PM Reply
I ride a ronix covin with one boots one the wake, and the wake is what i ride 90% of the time.
But im getting an annual pass this summer to OWC so im gonna be riding cable probably twice a week.
I really wanna get a slingshot response but i dont want to spend money on a set of slingshot bindings when i have some great bindings already!
Is it true that using bindings that arent slingshot will screw up the flex of the board?
NEED OPINIONS!!
Old    Jagermaster (jaegermaster)      Join Date: Sep 2002       11-05-2008, 5:00 AM Reply
BS. I have had my Ones, Byerley's and Transits in my response. The board rides the same except for the difference in binding feel. Make sure you either use washers or get shorter screws. The One screws are too long for the Response.
Old    Alan Slabaugh (alans)      Join Date: Aug 2005       11-05-2008, 7:33 AM Reply
They work great. Just get shorter screws or add a washer.
Old    Tom Adams (gunnertom4593)      Join Date: Sep 2008       11-05-2008, 2:22 PM Reply
ok thanks guys..i guess saying the ronix boots would screw up the flex is just marketing to get you to buy board and bindings from them
Old    Kyle (Slingshot) (kylenautique)      Join Date: May 2008       11-05-2008, 4:19 PM Reply
Using different boots other than slingshot boots will take some of the flex out of the tip and tail. The tip and tail flex the most on the boards. This is because the traditional boot style plates stick out farther then the slingshot mounting 4 hole mounting system. It makes the board ride a little stiffer.
Old    Jeremy Byrom (wakerider111)      Join Date: Jul 2006       11-05-2008, 6:02 PM Reply
^^^ like kyle said ^^^
i think "screw up" would be an exaggeration. but with that said, the 4 hole system was in part to take FULL advantage of the flex... even if it only amounts to be a small percentage in the end.
Their inserts are also independent of each other (i.e. not a line of inserts attached to a ridged metal plate). So, even for those that don't use the 4-hole they have done what is possible to make the ride flexy-nice
