10-30-2008, 10:33 AM
Maybe somebody can clear this up for me. Is a slow board slow because it has good fin hold and is there fore slow to turn? Or is a slow board slow because it does not have much in the way of fins and therefore dose not MAKE you travel as fast when on edge as a board with huge fins? The terms slow and fast are kind of ambiguous and i want to know what people mean when they say slow or fast.
10-30-2008, 10:38 AM
you're on the wrong track. ride an 06 murray (a lot of rocker) and then ride a shane or randy harris board(a lot less rocker). the rocker is what makes a board slow or fast a lot more so than fins. less rocker = less drag = faster. more rocker = more drag = slower. one isn't always better than the other, it's personal preference.
10-30-2008, 11:20 AM
Even more enlightening would be to jump on a roam. Those things are as fast as it can get as far as boards are concerned.
10-30-2008, 1:04 PM
I 2nd the roam being super fast
10-30-2008, 1:28 PM
or jump on the New hyperlite MAREK that board is almost as fast as the roam...the closest board i've riden to the roam for being fast. but still can grab an edge
10-30-2008, 3:03 PM
3 stage boards are typically slower than continuous boards as well... BUT this might be linked more to the whole rocker-amount as etiology. EXAMPLE: If the 3-stage boards out there were NOT to have a flat spot but a continuous arc then they would have an unbelievable amount of rocker! and just in case... rocker is the measure of bend and is measured by the distance between the ground and the tip/tail when the board is set on the ground
10-30-2008, 3:10 PM
IMO a lot of fin also slows a board down.
10-30-2008, 4:20 PM
I agree with J-Rod. My premier is much faster without the center fin in. And by faster, I mean it feels like it moves quicker when it is on edge.
10-30-2008, 4:23 PM
yeah i agree with j-rod also...i put some tiny hyperlite shank fins on my ronix covin(already fast) and it made it even faster and a lot more fun to ride
10-30-2008, 6:51 PM
the board speed, in short, is how fast the board will move towards the wake when you put it on edge. Some boards, with the same amount of edge pressure, will glide faster across the surface than others. This has to do not only with amount of rocker, but rocker degree as well. The 06 07 murray, with over 3 inches of rocker was very slow, but so is a Ronix Mana, which has a rocker degree of over 10, If i remember correctly. (degree is what angle the board's profile rises from a flat surface at the tip) That's why a 3 stage with a late kick and 2.5 inches of rocker will be slower than a continuous with the same amount of rocker.
10-30-2008, 7:45 PM
O'Brien boards utilize the Delta base to make them even faster then a board without. This allows them to make some of the fastest 3 stage boards out there. Big pop with low drag!
10-30-2008, 8:01 PM
also the new hyperlite and byerly shapes have a combination of 3 stage and continuous. the murray has a pocket cut out in the tip and tail to give it a 3 stage pop when flat and a continous fast edge. the byerly monarch has a blended rocker line that has a continuous rocker on the edge but rolls into a 3 stage in the center. the byerly is the fastest normal(not roam) board i have ridden yet
10-30-2008, 10:58 PM
I went from an 05 Parks, that was unbelievably responsive AND fast to the wake, to the 06 Premier, which was less responsive and had a steady, but slower approach to the wake. My new board, the Covin is very responsive, and FLIES to the wake. I look at Fast as reaction and speed towards the wake.
10-31-2008, 12:38 AM
Lets not forget phasers/chevrons/aeration pockets
10-31-2008, 7:14 AM
hahahaha!!!
10-31-2008, 7:26 AM
+1 JJakober... The O'Brien boards Delta base has really sped their boards up pushing them to the top of my list (I ride the 139 Natural).
10-31-2008, 8:41 AM
In snow (skiing and boarding) the longer the ski's/board the faster it was because it had more surface area on the snow, distributing the weight over more area.... is this true in wakeboarding as well, so that a continuous board has more surface area touching the water than an agressive 3 stage of the same length?
10-31-2008, 8:48 AM
John, the longer the board the faster as well but for different reasons and conditions. If you are riding slow, a larger board will be faster since it will give more surface area = more float. If you are sinking a board because you are too heavy for it, you can speed up to compensate.
10-31-2008, 4:04 PM
I ride a substance (not slow, but not fast either) do you think I could cut slits into the tip and speed it? I also noticed older hyperlites have divots in the bottom, could I do something like that to speed my board up? I want it be a fast board and release off the wake like vaseline.
10-31-2008, 6:15 PM
Luke -The Substance is a super slow board...I rode one for 3 years, not sure you could do anything to speed it up...great board to learn rotation tricks on.
