Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through November 07, 2008
Old    D C (dirwoody)      Join Date: Apr 2003       11-01-2008, 11:03 AM Reply
For those with winches, have built them, or used them, I have some line questions:
Where did you get yours?
What's the best place you know of to find one?
How thick did you go?
And how long did you go?
Thanks!
Old    Corey James McKenna (coreym)      Join Date: Sep 2008       11-01-2008, 11:38 AM Reply
You can order winch line through you Accurate/Hyperlite dealer. They can order different lengths and types of line. If they don't know they can order this line please have them call Corey @ Hyperlite.
Corey M @ Hyperlite
Old    Jeremy Byrom (wakerider111)      Join Date: Jul 2006       11-01-2008, 2:58 PM Reply
i hear about bullet lines alot, check this
http://www.bulletlines.com/winch-rope-1000.htm
Old    Andy Nintzel (andy_nintzel)      Join Date: Sep 2004       11-02-2008, 8:48 AM Reply
Ken Land at Bullet Lines will hook you up!
Old    Josh (romes)      Join Date: Sep 2006       11-02-2008, 8:51 AM Reply
we've got a couple of thousand feet of proline on ours.
Old     (kampus96)      Join Date: Oct 2005       11-02-2008, 10:17 AM Reply
http://www.reddenmarine.com/site/new-detail.cfm?id=AMRAMSTLBLU764
works perfect.
Old    Josh (romes)      Join Date: Sep 2006       11-02-2008, 5:31 PM Reply
good -ish Grantski
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       11-04-2008, 7:26 AM Reply
I 2nd the 7/64" amsteel $h|ts da bomb
Old    DANIEL ULINE (fbmuline)      Join Date: Oct 2008       11-04-2008, 8:06 AM Reply
I BOUGHT 1000 FOOT OF ACCURATE FOR MINE. GO TO HYPERLITE DEALER. WORKS GREAT. SMOOTH PULL WITH ONE CONTINUOUS ROPE RATHER THAN SEVERAL PUT TOGETHER.
Old    D C (dirwoody)      Join Date: Apr 2003       11-04-2008, 8:42 AM Reply
How long is too long though?
And what did you guys do for your spools?
Old    Josh (romes)      Join Date: Sep 2006       11-04-2008, 8:48 AM Reply
we have a couple thousand feet on ours.
pm CIE Al about it he built ours.
Old    D C (dirwoody)      Join Date: Apr 2003       11-04-2008, 8:50 AM Reply
Sounds good!
I'll have to post pics once everything gets underway.
Also, how many of you guys went with a CVT vs a centripital clutch?
Not sure if I spelled that right
Old    Josh (romes)      Join Date: Sep 2006       11-04-2008, 8:58 AM Reply
make sure you put a torque converter or if you plan on deep water starts.
Old    RileyBangerter (steezyshots)      Join Date: Feb 2008       11-04-2008, 9:06 AM Reply
Also 1000 feet of Accurate line on ours, I would go that way. Great line!
Old    Ken Land (bulletlines)      Join Date: Apr 2005       11-04-2008, 10:15 AM Reply
Darin,
We have releasing spools and our 2009 Aluminum Pimp Winch frames available. Our releasing spools freewheel on it's own set of highspeed ball bearings when pulling the rope out; nice feature to have so you dont have to pull out rope against the engine. Heres a pic of one of our spools mounted.
Bullet Pimp Winch frames are made of polished aluminum tubing and weigh less than 25 lbs. Ou new frames are just plan pimp.
Ken Land
Bullet Lines
www.bulletlines.com
Old    Andy Nintzel (andy_nintzel)      Join Date: Sep 2004       11-04-2008, 12:38 PM Reply
KEN HOOK A BROTHER UP WITH A WINCH!!!!!!!!
