Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through November 07, 2008
Old    David Christman (lfrider92)      Join Date: Sep 2008       10-21-2008, 8:37 PM Reply
i can clear the wake with the board like this. but i dont get alot of pop. should i be cutting harder? thanks guysUpload
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       10-21-2008, 8:47 PM Reply
More loading the line harder than a harder cut. Your almost flat coming in. Before you start in towards the wake, let the board "sink" and bite a bit and then progressively edge harder and harder to the wake and DON'T let off your edge/ line tension and lock your legs at the bottom of the wake, then you'll boost...
Old    David Christman (lfrider92)      Join Date: Sep 2008       10-21-2008, 8:51 PM Reply
alright thanks. i can clear the wake no problem like that. just not alot of pop. ill cut out around 15 feet. and once the board starts to head back toward the wake ill just start leaning in and straighten my legs at the top of the wake. but i was just looking thorough pics over the weekend. and realized how flat my board was and how it could be my problem
Old    Darren Yearsley (ralph)      Join Date: Apr 2002       10-21-2008, 10:31 PM Reply
IMO you need to even up your weight dist. More weight on your front foot. I looks like you are leaning away from the wake which normally results in crap pop and front of the board skying up.
Old    Nick Tomsyck (sidekicknicholas)      Join Date: Mar 2007       10-21-2008, 11:15 PM Reply
lucky for you all I am extremely bored and had time to do the research and make this amazing graph.
The closer to the wake you get the harder the cut should get.... start at 10%, you get closer go to 20%, closer still 30% so on and so on until you reach the wake and should be cutting at 80%+
Old    Ben Ax (hawkeye7708)      Join Date: Feb 2007       10-21-2008, 11:21 PM Reply
My god... it's nearly exponential!
Old    David Christman (lfrider92)      Join Date: Sep 2008       10-22-2008, 8:37 AM Reply
hey everyone. thanks a ton. your right about my board going straight up. 90% of the time the frot my my board is pointing straight up while im in the air. thanks alot guys
Old    Matt B. (mxflyer281)      Join Date: Oct 2007       10-22-2008, 10:08 AM Reply
Haha the graph... but yes they r right
