Old    Big Mo (liquid_helix136)      Join Date: Oct 2008       10-15-2008, 10:09 AM Reply
Im looking to try one of these but not sure which one to go with first, i have 100% consistent raleys but my toeside cut could use a tad bit of work (only do ts b-rolls/f-rolls) Which would be easier to go with at the beginning?
Also is an Indy glide basically a 911 with an indy grab?
Old    Dave (knarbar)      Join Date: Nov 2006       10-17-2008, 2:31 PM Reply
If your not comfortable on your toeside edge yet Id say skip the batwing. Or just take it slow and let the board drift out a little more each time you do it. If your consistent on raily's try the indy glide. Also if you can get the courage to try one off the D up then do that becuase it gives you a little more time in the air and more straight up pop.
