Old    BLAIR BARHAM (jonblarc7)      Join Date: Jul 2006       09-16-2008, 11:56 AM Reply
I have a hyperlite Broadcast 4'9" right now I'm riding it with the center fin removed. I can do 3's with the rope but I use the rope to help me break the fins lose. Should I remove the outside fins or do I just need to work on the way I spin more.
Thanks
P.S. I'm behind a super sport which needs alittle more ballast because the wake is kinda of small.
Old    Show (bigshow)      Join Date: Feb 2005       09-16-2008, 6:12 PM Reply
I find the Broadcast hard to spin. You might try filing down the outside fins or look for smaller fins.
Old    Joe B (sailing216)      Join Date: Oct 2007       09-17-2008, 7:07 AM Reply
I have the same board and I'd remove the outer fins, and shave a bit off the center fin. My new board that spins like a top has a 1" high fin. It still grabs well but no problem getting the board to spin.
Old    Nate Hudson (iamnathanhudson)      Join Date: Dec 2002       09-17-2008, 7:30 AM Reply
put the shorter aluminum fins in all the slots. It should be easy enough to spin but grip when you need it.
Old    BLAIR BARHAM (jonblarc7)      Join Date: Jul 2006       09-17-2008, 7:52 AM Reply
Thanks, I think I got some Hyperlite 1.0" fins laying around. I just wasn't sure if they were the same bolt pattern.
