Old    daveyboy            04-09-2003, 4:34 AM Reply
I have a 21' i/o with 5.7 I have a 14x19 3 blade alum. prop right now. stock is a 13.75x 21. I am going to add ballast and a 4 blade prop. ss is not possable where I use my boat. do I order a 4 blade in a 14x19? I am after a big wake and speed control. PP is not an option right now.
Old    buttskimmer            04-09-2003, 6:29 AM Reply
Dave,
I have the volvo and use the 14.5 x 19" 3 blade alum prop now for boarding with the ballast in. I also have looked at the 4 blades - wallet doesn't support it yet. The more power you have at low rpms will help keep the speed. If you can over RPM the engine at WOT alittle its ok because you can chose NOT to push the throttle that far. Add the ballast first - run with 19" prop and WOT the engine making sure you DON't go over the MAX rpms. If the rpms at WOT are slightly about max rpms for your engine then the 19 - 4 blade should be the ticket. If you have alot of throttle left at WOT then you might want to seek out a higher # pitched prop.
~S~
Old    jmccallum            04-09-2003, 11:58 AM Reply
Scott;
I have a Volvo 4.3 v6 on a Four Winns 18'. What size is your boat and motor?
