Old    erlingl            04-04-2003, 12:25 PM Reply
What can i do to a v8 boat motor to get more power put of it
Old    erlingl            04-04-2003, 12:26 PM Reply
has anybody put aftermarket intake manofolds or things like that on.
Old    wakegurrrl            04-04-2003, 12:33 PM Reply
The real question is more speed. Before you tweek the engine, figure out if it will make a difference in speed. On most direct drives, even 20-30 hp adds 2-3 mph.
Old    Sean M (magic)      Join Date: Mar 2002       04-04-2003, 12:41 PM Reply
Change your prop. If you are looking for a better hole shot, decrease the pitch of your prop.
If you are looking for higher top speed (slower hole shot, worse speed handling) increase the pitch of your prop.
Might be cheaper that eeking out an extra 20-30 hp.
Old    sprucie            04-04-2003, 1:15 PM Reply
Changing props will lengthen the life of your engine as well.
Old    drmalibupws            04-04-2003, 3:44 PM Reply
For every $1000.00 you spend You will only gain 1 mph, It is the hull not the engine.
Old    erlingl            04-04-2003, 5:15 PM Reply
what do you add to get an extra 20-30 hp, the boat is a crownline 202 with a with a 305 murcruser
Old    Mik (norcalrider)      Join Date: Jun 2002       04-04-2003, 5:47 PM Reply
Crownlines might actually take better to extra HP than a Direct Drive. There are marine superchargers. K&N makes air filters that claim to increase HP and torque.
K&N www.knfilters.com/marine/default.htm
Whipple www.whipplesuperchargers.com/products.asp
Old    bigd            04-04-2003, 5:59 PM Reply
These guys can hook you up for days...
http://www.hotboat.com
Old    ManFox (h20jnky)      Join Date: Mar 2003       04-04-2003, 8:17 PM Reply
Have you thought about a nose-cone on lower drive? Maybe high-grade spark coils, performance air filter, twin tip spark plugs, aluminum intake manifold, thru-hull exhaust conversion, stainless "chopper" props, bennett trim tabs, high output ignition, yellow top batteries, extra ventilation into engine compartment.......etc. etc? www.hotboat.com is definitely your "power" connection. Good luck!
