Old    Jason (corerider)      Join Date: May 2008       08-20-2008, 5:49 AM Reply
What's the trick to doing a nose press for instance? I've tried them in the past, but never get what I would consider a real press. Maybe I'm just not putting enough weight forward and it takes more than I thought. Any suggestions?
Old    Louise (pvsawyer)      Join Date: Mar 2008       08-28-2008, 8:23 PM Reply
What works for me is not only pressing on my forward foot, but also leaning a bit against the cable (or boat). Whatever you do don't try and lift your back leg- it won't work. Focus on keeping the handle low, pressing on your front foot and leaning against the line. Take a look at my profile pic- it may help you. I started out learning a poked nose slide (which is much easier) then eventually transitioned to real nose presses. You may want to try nose slides first if you can't already do that.
Old    Chris Hopf (chrishopf)      Join Date: Sep 2007       08-30-2008, 12:25 PM Reply
I would ollie into it.. They are much easier that way!!!
CH
