Old    lakeside5_10            06-19-2008, 4:41 AM Reply
if you could would you use it , if all you had to do was to shape the rails and cut in boxes , you think it would be to stiff even if you dont use a center stringer at 1.5" thick ??
Old    Jeff Walker (surfdad)      Join Date: Sep 2004       06-19-2008, 5:32 AM Reply
I've used it on the rails only and it's really stiff. Stringerless EPS is 2+ pound. I think you could use it without a stringer with an adequate glassing schedule.
Old    lakeside5_10            06-19-2008, 7:20 AM Reply
6x6 & 6x6 is what i would go with , i would have to buy 8 cores to get it . Jeff would you think it would flex enough
Old    lakeside5_10            06-19-2008, 7:51 AM Reply
i might try 3lb. at 1" thick on a shortend version of the xbc fish, make it 4.8 with a flat bottom with 2.5 nose and .5 tail rocker and install a quad fins
