Old     (phenom_1819)      Join Date: Jan 2008       06-18-2008, 4:00 PM Reply
I'm relatively new to wakesurfing, and prior to buying the Loogey had only ridden a friends' CWB Ride. I liked how easy the Ride was to push off the wake. I'm having trouble with the Loogey, and have the speed line fins... am debating getting the trick fins. Good idea or not? Don't know if it matters, I'm 5'8 160 lbs.
And does anybody know where I can buy the trick fins in the Seattle area? Checked Extremely Board, they don't have them. I've checked all over online -- inlandsurfer.com will let you order direct but it works out to like $63?!? Retail is $45.
Thanks in advance.
(Message edited by phenom_1819 on June 18, 2008)
Old     (surfdad)      Join Date: Sep 2004       06-18-2008, 4:43 PM Reply
Inland's Speedline fins are proprietary - you can only get them thru Inland or an Inland dealer, most likely a special order
Smaller fins will loosen up the tail, at the expense of drive.
Old     (phenom_1819)      Join Date: Jan 2008       06-18-2008, 4:49 PM Reply
Is drive the same as speed?
Old     (surfdad)      Join Date: Sep 2004       06-18-2008, 5:05 PM Reply
Yes, indeed.
Old     (masonwakerider)      Join Date: May 2003       06-20-2008, 7:22 AM Reply
cope and mcpheters in woodinville has a set of two in the pro shop i dont know the price, ask for will
Old     (phenom_1819)      Join Date: Jan 2008       06-20-2008, 8:15 AM Reply
Perfect... I'll give them a call today. Thanks for the tip, WAlove.
Old     (liljohn)      Join Date: May 2007       06-20-2008, 8:56 AM Reply
you can also try brandon at bakes marine proshop. If there not in stock ask him to go get them. tell him lil john sent ya. as long as hes not swamped he can do it for ya.
Old     (phenom_1819)      Join Date: Jan 2008       06-20-2008, 2:33 PM Reply
Thanks for the tips, guys... Copes in Woodinville hooked me up. Looking forward to trying them tonight.
