Old     (prose)      Join Date: May 2008       05-09-2008, 6:44 AM Reply
Ok, these are the tricks i can do..I have listed them as i do them in my run..what do you think..can you list them in the order you think would make it a better run.
First pass
Method 180
Blind 180 (in flats) into Half Cab
Heel 360
Scarecrow
Heel Tail Grab
Second Pass
Backroll
Toe side 360
Tantrum
Toe side Backroll
Front Roll
Old     (aussie_stu)      Join Date: Sep 2002       05-09-2008, 2:43 PM Reply
I'd split your inverts up a bit in the 2nd pass, put something else in there, maybe swap your heel 3 and the heel fronty? always put the one your not 100% with at the end of the 1st run,
Old     (trevorcurry)      Join Date: Jun 2007       05-11-2008, 1:32 PM Reply
Most comps I have ridden in give extra intensity points if you start your run with a higher point value trick. You could start your 1st pass with a backroll and move the method 180 into the first trick of your second pass.
Just my 2 cents.
Old     (mallenger)      Join Date: Jun 2006       06-05-2008, 1:44 PM Reply
dude, if you've got a ts 3, go ahead and take it to 5.
My $.02
Old     (hawaiianstiln)      Join Date: Oct 2004       06-05-2008, 3:42 PM Reply
I would agree with Trevor too. I usually throw my railey or 911 first (something big) and then W2W grabs and 180's then start throwing HS front flip, tantrum, backroll, TS front.
My second pass would probably kick off with a big Heelside Front into the flats now that I can land that consistantly.
Throw a big scarecrow into the flats first and then some of your grabs and 180's on the first pass. At the end of your first pass, throw your heel 3. Second pass looks good I think! Especially since you have a spin in there.
Just don't throw anything twice.
(Message edited by hawaiianstiln on June 05, 2008)
Old     (wake_the_states_222)      Join Date: Jun 2008       06-16-2008, 10:20 PM Reply
im no pro or anything but if you got a grab or two you can throw in with those inverts it will add some sick style points into your run...
even simple things tend to tweak out inverts and grabs...
Old     (alanp)      Join Date: Apr 2001       06-17-2008, 8:59 AM Reply
the end of your run end with two ts tricks the ts backroll then a ts front roll?? that needs to be fixed
Old     (codykauz)      Join Date: Jul 2007       06-17-2008, 6:02 PM Reply
do you guys think that his list would make a decent run for an int tourny?
