Old    Ronia (ladythump)      Join Date: Jul 2004       06-01-2008, 10:17 PM Reply
Do you keep the boat parallel to the boat (like when you start with the board on the surface of the water) or do you hold the board pointed at the boat when starting with the board underwater?
Old    Jonny (wakeboardlasvegas)      Join Date: Mar 2007       06-02-2008, 7:46 AM Reply
Parallel.. same principles apply as to how you would normally get up.
Old    Ronia (ladythump)      Join Date: Jul 2004       06-02-2008, 9:57 AM Reply
thanks man, i'll give it a try!
Old    Mellow Man (mellowman)      Join Date: Jul 2007       06-02-2008, 11:42 AM Reply
I'm glad you got it, but it is perpendicular to the boat not parallel :-)
boat -> |
board -> -
Old    kal schultz (kal_dude)      Join Date: Apr 2006       06-02-2008, 9:15 PM Reply
keep your weight on your heels!!!!!
Old    Keith (hawaiianstiln)      Join Date: Oct 2004       06-03-2008, 3:23 PM Reply
yup, keep your weight on your heels is big. In the beginning when you start to do this all the time, you will want to kick the board a little in front of your body while standing up under water, especially when you are ready to be pulled out.
Old    Tony (guitsboy)      Join Date: Aug 2005       06-09-2008, 12:34 PM Reply
Keep the handle down low, under water, so you get pulled from teh center of gravity. I usually have mine just a touch above my center, and I lean back slightly just as the rope goes tight. Way easier than a surface deep water start once you get the hang of it.
