Old    Chasin7 T (chaser)      Join Date: Sep 2006       06-03-2008, 10:23 AM Reply
I got a friend who has an 07 Centurion Lightning. It has a single ballast tank in the floor. Not sure how much it holds? He's trying to get the wake dialed in. Any suggestions on rope length and speed. Is added ballast a must?
Old    Kevin R Baugh (krbaugh)      Join Date: Mar 2002       06-03-2008, 10:51 AM Reply
Check out Centurion Crew there is a thread on that subject
http://www.centurioncrew.com/white-wash-t195.html&st=20#entry1636
Old    AtTheLake (bmartin)      Join Date: Jan 2007       06-03-2008, 2:12 PM Reply
I have an 04 Lightning and here is my set up. Center tank, 550 sacs in the rear locker, and 2 550s under the front bow seats. I fill the bow sacs up to the point where you fill the under seat compartments with water which is probably about 1/4 to 1/3 full. I fill the center tank, and depending on human balast, will fill rear sacs 1/4 to 3/4 full. I used to slam the rear sacs full almost all the time, but with gas prices, I am finding the wake with a little less balast to be sufficient. The center balast alone does not put out enough wake for people wanting to go faster than 20 or 21 MPH IMO, but it is pretty decent sized at 20MPH and below but not quite as hard as faster speeds.
I pull people on 60' up to 80' lines and with speeds between 18 and 23 MPH depending on skills and preferences. Faster speeds will require more weight and vice versa.
I also put the wake plate down a little more on the drivers side to keep it cleaner.
Old    doby (reelhooker)      Join Date: Jun 2008       06-06-2008, 11:05 PM Reply
i have the same boat... how do you adjust the wake plate, i would like to clean up my wake a little bit.
