Old     (spencer3840)      Join Date: May 2005       06-05-2008, 5:22 PM Reply
What product should I use to remove wax on my gelcoat that won't hurt it?
Old     (wake_upppp)      Join Date: Nov 2003       06-05-2008, 6:09 PM Reply
You can buy a Wax & Grease Remover at an auto parts supply store or just plain old Naptha. Lighter fluid will work as well. None of these will harm gelcoat. Wipe it on wet and follow with a dry soft towel to remove. All these evaporate rather quickly.
Old     (ridininmd)      Join Date: Jun 2006       06-05-2008, 6:54 PM Reply
dish soap.
Old     (boss210)      Join Date: Jun 2006       06-05-2008, 6:54 PM Reply
Just go with a window cleaner. It will strip off the wax and not damage your luster.
Old     (zacharoo)      Join Date: Nov 2005       06-05-2008, 8:22 PM Reply
Acetone is the better choice. Removes everything and will not hurt the gelcoat ever. Rewax area around stickers.
Old     (wake_upppp)      Join Date: Nov 2003       06-05-2008, 8:38 PM Reply
Acetone is a little on the strong side for me, and if the surface is hot, could stain. The Naptha based wax and grease removers are what is used professionaly around boat and auto refinishing shops. That or the new generation water/citrus based wax removers and degreasers.
Old     (trdon)      Join Date: Sep 2007       06-05-2008, 9:51 PM Reply
I have always used dish soap to strip wax off of everything.
Old     (spicychalupa69)      Join Date: May 2005       06-05-2008, 9:55 PM Reply
Don i see you're back on WW !! no more cussing alright my man! ha!
To add to the discussion, i too have used dish soap, works wonders!
Old     (wake_upppp)      Join Date: Nov 2003       06-05-2008, 10:16 PM Reply
It really depends on what's been applied to the surface. The thing with soaps is they are made with surfactants which basicaly are a wax type of lubricant that can leave a film on the surface. There are many high tech Polymer waxes and surface sealants that soap won't touch as far as taking them off the surface. These Polymer's actualy chemicaly bond to the surface and are not easily removed.
Old     (etakk7)      Join Date: Apr 2006       06-06-2008, 9:06 AM Reply
rubbing alcohol
Old     (wakescene)      Join Date: Feb 2001       06-06-2008, 11:51 AM Reply
Dish Soap. Wash it twice. Regular Dawn for example has a high alkalide content that is the agent to remove wax on hulls and auto finishes, but won't hurt anything.
Cheap, simple and easy!
Old     (hydrophile)      Join Date: Aug 2007       06-06-2008, 12:02 PM Reply
+1 to the Dawn Dish soap
Old     (juniorhawk)      Join Date: Jul 2004       06-06-2008, 2:16 PM Reply
Nothing fancy here but I have a foolproof system.
I always use rubbing alcohol to prep a small area for a sticker. Just rubbing alcohol and elbow grease for the small stuff. On big decals I use alcohol to prep the are then regular windex, but I super shine the area until its almost sticky itself. Big stickers don't even budge when you do it this way, even the little parts.
