Old    Cole (wakeboarder46)      Join Date: Jun 2007       06-05-2008, 5:57 PM Reply
I need help on my 360s. I have tried it many times n have come close to landing but sometimes i dont spin all the way or dont get enough air.
please post suggestions tips anything to help me out
-Cole
Old    Cole (wakeboarder46)      Join Date: Jun 2007       06-05-2008, 5:59 PM Reply
here is a picture:
Old    Justin Houston (adrenalindustries)      Join Date: Jun 2008       06-06-2008, 6:43 AM Reply
Dude I have the same problem!!! I hate it last year I was landing them so clean! and now I can't land anything!
Old    alan plotz (alanp)      Join Date: Apr 2001       06-06-2008, 10:18 AM Reply
did you check out the thread below about 3's. this gets covered all the time. simply put youre off axis. check the thread below for some tips to keep you on axis. and check eubanks' thread too
Old    Stew (aussie_stu)      Join Date: Sep 2002       06-06-2008, 4:34 PM Reply
leave the spin later and you'll stay on axis, remember to pop, then pull the handle and spin
Old    Cole (wakeboarder46)      Join Date: Jun 2007       06-06-2008, 5:10 PM Reply
ok thanks ill try tht
n will going at a slower speed then usual help like going at 16 mph
Old    Stew (aussie_stu)      Join Date: Sep 2002       06-06-2008, 11:35 PM Reply
no riding slower will make it harder to get a decent cut and jump, just try em at the speed you usually ride at.
Old    Frankie Cramer (troutpac)      Join Date: Feb 2008       06-07-2008, 5:33 PM Reply
360's almost made me lose my mind last year. I'd get em down ,relax, try em again the next day and get worked.Very frustrating. You have to be patient and ride thru the wake on axis then pull yourself around. Use a mellow edge.Im working on backrolls now and the 360 edge catching falls are nasti compared to the backroll falls. Also,I would do a couple of surface 360's to get the position of leaning away from the boat a bit.Then try it at the wake. Good luck
Old    Cole (wakeboarder46)      Join Date: Jun 2007       06-08-2008, 1:41 PM Reply
Stew (aussie_stu)
even though some people say it is easier?
Old    Stew (aussie_stu)      Join Date: Sep 2002       06-08-2008, 6:55 PM Reply
I learnt em at regular speed, I can't stand riding slow, puts me off.
one thing that I did was learnt them wrapped to get the hang of the spin and landing, then progressed to the handle pass, wrapped ones are easy as pie.
Old    Cole (wakeboarder46)      Join Date: Jun 2007       06-09-2008, 8:37 PM Reply
how do you do the wrapped ones?
Old    Stew (aussie_stu)      Join Date: Sep 2002       06-10-2008, 11:06 PM Reply
wrap up, pop off the wake and spin
it helps if you have a T-handle, but basically you "wrap" up, the handle is in your front hand, but your front arm runs behind your body, you have your back hand on the T-piece, cut in pop up then give a little yank on the T-piece and hold on.
Old    jamie Nicol (jamien)      Join Date: Jun 2008       06-15-2008, 5:01 AM Reply
I can only land 3s off a double up. Each hit is a bit different so it stops you thinking about it too much.
Old    Cole (wakeboarder46)      Join Date: Jun 2007       06-19-2008, 11:59 PM Reply
how do you make a double up? i never tried one
