Old     (rarasaurus)      Join Date: Apr 2008       05-26-2008, 9:48 PM Reply
Hi
I have recently purchased a supra21v with a boat mate trailer. My issues was that the 5 pin conversion did not allow for the Volvo XC90 to go in reverse and disengage the brakes.
My question is what is the color scheme.
There are 3 blue, 1 white, 1 yellow, 1 green, 1 green and brown, and 1 yellow and brown.
I was wondering what they all are and in what position they go.
1 Parking lamps
2 Charging
3 Right indicators
4 Electrical brake
5 Ground
6 Left indicators
7 Reserve
The above are the 7 positions in the 7 pin attachment. Please let me know what color wire goes to what pin.
Thanks George
Old     (lavinder)      Join Date: Mar 2008       05-26-2008, 9:54 PM Reply
You should be able to get a 7 to 5 pin adapter so you don't have to worry about which wire goes where.
The adapter should work. The blue wire on the five pin is for the reverse. You can bypass the 7 pin plug and run a wire to a reverse light. This can be found with a test light and the vehicle in reverse. I just wired my truck up to the five flat pin for my new Supra.
Old     (oshelton)      Join Date: Oct 2001       06-02-2008, 6:56 PM Reply
1 Parking lamps - Brown
3 Right indicators - Green/Brown
5 Ground - white
6 Left indicators - Yellow/Brown
3 & 6 may be reversed. Look at the plug on the left or right tail lamp for the color.
One of the outlets should provide for current from the reverse lamp circuit when the vehicle is in reverse. This will power the three blue wires. Two are for the reverse lamps (left side & right side), one is for the reverse lockout solenoid in the actuator which locks out the trailer brakes when backing.
Old     (thesack)      Join Date: Mar 2008       06-03-2008, 2:18 PM Reply
Tell the cheap ass dealership you bought your Supra from to give you the adapter.
If they wont do it go to your auto parts store and buy the adapter.
Old     (jpuckett)      Join Date: Apr 2005       06-03-2008, 2:24 PM Reply
George
Is the 7 pin harness on your Volvo factory installed? If it is then it should work with the 7 to 5 pin adapter. If not the harness could be wired wrong and would need to be changed. Also some vehicles require a relay to be added to allow the reverse lights to work on the trailer harness to release the brakes in reverse.
Old     (acurtis_ttu)      Join Date: May 2004       06-03-2008, 2:51 PM Reply
Ghetto...lol. Flip the plug around when you get to the ramp and turn on your headlights.
(Message edited by acurtis_ttu on June 03, 2008)
Old     (acurtis_ttu)      Join Date: May 2004       06-03-2008, 2:53 PM Reply
and yes it works, lol
Old     (kenteck)      Join Date: Jan 2005       06-03-2008, 2:55 PM Reply
Trailer Plug Wire Schematic
White: Ground
Green: Right Turn / Brake
Yellow: Left Turn / Brake
Brown: Running Lights
Blue: Reverse Lights
